Other Best sub £200 laptops for charity project
Discussion in 'Hardware' started by MiNiMaL_FuSS, 27 Feb 2018.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Hi all,
    I'm looking at creating a budget ICT suite for disadvantaged young people in King's Lynn as part of a wider youth project that I'm responsible for.
    These laptops would largely be used for browsing, information gathering, job searching, etc.
    I'd like them to have a least a 14" screen and be a little more robust for public use, which eliminates the vast majority of netbooks.
    I was considering something like this (although it currently out of stock):
    https://www.tesco.com/direct/hp-14-...-1tb-black-laptop/760-8535.prd?skuId=760-8535
    Anyone have any alternative suggestions or useful links to a company that might do us a deal?
    Budgets are tight, so I'm ideally looking at something for around £200 per laptop.
    Many thanks,
    Ben / FuSS
  2. sandys
    sandys Well-Known Member
    26 Mar 2006
    would a desktop not be better as easier to replace broken bits independently and often cheaper than laptops?
  3. sjhujh
    sjhujh Member
    1 Feb 2008
    Maybe a bit left field, but what about Chromebooks? They'd give you all the functions you're after and there's not much to go wrong with them?
  4. MiNiMaL_FuSS
    24 Dec 2003
    I know where you're coming from - but it's useful if they can be more mobile, possibility of using at additional venues or moving more easily for training sessions, etc.
  5. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
  6. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    This seems like the same chassis as PCSpecialists' Lafité series. If it is, they're solid little machines especially with an SSD. The fan spools up quite a bit but some liquid metal should help with that.
  7. MiNiMaL_FuSS
    24 Dec 2003
    Looked at Ez Books and think they're excellent machines, but for a charity buy I probably can't justify buying from outside the UK, I especially couldn't justify "accidentally" avoiding import duty as you or I would as individuals either. Might try to find them from a slightly more reputable UK source though.
  8. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    Having used the previously A4 APU range on a laptop with a rust spinner, slow is not the word I would use for it.
    Most charities that I have worked for are actually not VAT registered as its more work than its worth in savings.
    I have a contact at Dell Outlook sales that used to look after me pretty well. Let me know if I can introduce you.
  9. MiNiMaL_FuSS
    24 Dec 2003
    We are VAT registered but it actually depends on each funder/grant - if the funding you're using to purchase something is inclusive of VAT then you must pay the VAT on that item, even if you're VAT registered....it's a complicated old business!
    I'd definitely be happy to make any contacts that might be able to help us access charity rates on new or refurbished laptops, I'm currently after between 5 and 10 of them.
  10. nimbu
    28 Nov 2002
    I'll dig out her details and pm them to you.
    Have you had a look a techsoup? I can't remember what the UK arm is called now used to be called charity exchange.
    They offer access to foundation giving programs for smaller charities. Grants include hardware and software.
    That would be a good place to start.
  11. MiNiMaL_FuSS
    24 Dec 2003
    Thanks very much, appriciate it.
    Yes we use TT-exchange (their UK branch) for our Office and Windows licences, I do need to have a hunt around the website and see if there's any other helpful software kicking about though. I've not spotted any hardware opportunities sadly.
  12. Byron C
    Byron C Probably isn't Hitler, but definitely a muppet
    12 Apr 2002
    Is second-hand out of the window? Plenty of ex-corporate ThinkPads kicking around the place; they might have a bit of wear (shiny keys, knocks and scuffs, etc), but they're built like tanks and easy to repair/upgrade. I don't know of any off the top of my head, but there are companies out there selling reconditioned ex-corporate stock.
  13. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    I can get you what you need. Something like i5 Hp 8440s maybe? Robust, solid and pretty quick. I have an almost unlimited supply of these.
    Guest-16 and bsp like this.
  14. sonicgroove
    16 Mar 2011
    I work for Tier1 IT recycling.
    MiNiMaL_FuSS likes this.
  15. MiNiMaL_FuSS
    24 Dec 2003
    Thanks all, Sonic has sorted it for us :)
    bsp and Byron C like this.
  16. sonicgroove
    16 Mar 2011
    I did sort it, but unfortunately, MF didn't end up going for them. I have no idea why, as radio silence seems to be the order of the day. Made me look a bit of a plum in front of my new boss, which is.....unfortunate! Ah well, I tried to do a good turn....
  17. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    On a pretty different topic, do you ever get any proper vintage stuff in for recycling? Like, 8-bit, 16-bit era?
  18. sonicgroove
    16 Mar 2011
    Every now and then, we get laptops that I haven't seen since the early 80's!
    Also, it seems I was just left out of the loop. Red tape got in the way, so everything I said in the last post can be fully ignored. My bad!
  19. Gareth Halfacree
    4 Dec 2007
    Do me a favour: have a word in your boss' shell-like about possibly putting a few to one side as and when they come in, then taking some pretty pictures of 'em and getting in touch with me for an interview on the subject. "Lost Treasures of the Recycling Centre" would make a great feature for Custom PC!
    Vault-Tec likes this.
  20. sonicgroove
    16 Mar 2011
    I'll have a word with the gaffer and sort something out. Sounds interesting!
