Modding Best Tool for cutting a Window?
Discussion in 'Modding' started by jamiesurfs, 31 Oct 2001.
  1. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Please forgive my ignorance on this one, but what is generally reckoned to be the best electric tool for cutting a window in the side of a case?.:eek:
  2. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    depends what the material the case panel you are cutting.
  3. jamiesurfs
    21 Oct 2001
    That would be the side panel on a Globalwin 802. Possibly Steel, I think.:eek:
  4. Bursar
    Bursar What's a Dremel?
    6 May 2001
    I used a jigsaw on mine. Went through it like a hot knife through butter.
    Mask up the entire side panel (apart from the bit you are cutting). If your jigsaw has a metal base plate, put some masking tape on that as well (to stop scratches).
    Use decent quality metal cutting blades as well.
    That's about it really. Oh, wear eye protection, and cutting theroguh steel with a jigsaw is a rather noisey past time. If you have some ear defenders, wear them as well :D
  5. TiTch
    TiTch h2o cooled
    19 Oct 2001
    I used a jigsaw with a metal blade (I got my blade from homebase - easy to get) and it cut with no problems.
    Take the above advice and don't cut corners with the masking - the base of the jigsaw badly scratches unprotected paint. It knackered mine.
  6. linear
    linear Minimodder
    5 Oct 2001
    I Dremeled mine, which was an exercise in patience, mostly. If you go the Dremel route, it's doable, but remember it will take several passes over your cut to break clear through the metal. Forcing the bit through or using too much pressure just wastes cutting wheels.
    It took me two reinforced cutting wheels and about 45 minutes to cut this:
    I'd probably second the jigsaw recommendation, though, unless you need a high level of detail. I just don't own one right now.
  7. jamiesurfs
    21 Oct 2001
    Cheers for the advice guys. Looks like the Jigsaw is going to be the way to go then.:D
