Overclocking Best value upgrade while waiting for next Gen. CPU's
Discussion in 'Hardware' started by MSHunter, 11 May 2010.
  1. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    My rig:
    Asus P5K Delux wifi-Ap
    6650 @ stock 2.4 GHz
    8800GTS pre-overclocked 320 model
    4 gb ram
    500 F1 Samsung HDD
    I'm thinking of upgrading cpu and maybe GPU and keeping the rest until Intel's next gen. CPUs come as they will need new socket/mother board.
    My question is what is the best quad core 775 soc. CPU and how far can it be stable (folding stable) over-clocked using my Freezer Pro 7 cooler?
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    the legend of the Q6600 should suit you well
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I was facing the same thing..
    In the end I overclocked my E6600 (C2D 65nm) from 2.4GHz to 3.2GHz with a Freezer 7 Pro then bought a cheap Vapour-X 4870 1GB to replace my 8800GTS 320mb (same as yours).
    Admittedly the GPU purchase was more driven by the fact that the fan sensor on my 8800 died which meant it was always runing at 100% (too loud) but the 4870 only cost me £120. For the same price you can now get the ATI 5770 cards, lower heat, noise and power consumption although they have less memory bandwidth than the 4870.
    Are you willing to try an overclock of your existing CPU?
    I think the E6650 is a 1333 FSB running @ 2.33GHz. Assuming you don't want to spend much money, the P5K should o/c the E6650 well. Does anyone here have experience on what kind of o/c a 6650 can get on a P5K?
  4. stivalmighty
    stivalmighty What's a Dremel?
    11 May 2010
    Maybe a Q6600 and a 5770, I recommend the 5770 vapour-x, Great card!
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    can I keep the 8800 GTS folding and use a 5770 ?
    I have been looking for Q6600 but can not find any stock anywhere where it's stated as GO stepping/SLACR
  6. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    One other point I would defiantly want to keep the overall cost down 200 to max 300 pounds.
    Yes Folding is important and I want to keep doing it. 470s are too expensive for my tastes.
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    the oldest quad I can find is a Q8200 @ 100 pounds. Are these any good at OCing?
  8. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    iirc no - if you're after a good OC chip, try the E8400 - its only dual core, but mine goes to 4GHZ easily.... infact.. i should probably try to push it further some time soon.
    (i run it at 4ghz 24/7)
  9. merple
    merple What's a Dremel?
    18 Dec 2007
    If you are buying new or from a store, they should be the newer G0 stepping by now.
    You would be better off with a Q6600 for OC, goes for around 90 quid on ebay.
  10. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I don't suppose any one has a Q6600 laying around in a draw some where they don't need?
    (worth a shot)
  11. merple
    18 Dec 2007
    Well if you aren't in a rush, I plan on selling mine when I take apart my pc for upgrades/water.
    I still have quite the shopping list though, so not gonna be good for you if you want it soon.
  12. Guest-44432
    Guest-44432 Guest
    I have a QX9650 up for sale. PM if interested.
    Simon
  13. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    yeah I'm not in a rush, just want to do a cheap upgrade to hold me through the first 3-6 months of the new CPU launch so im not tempted to do something stupid and buy before the first price drop.
