Other Best Video Codec Pack?
Discussion in 'Software' started by Deders, 19 Apr 2012.
  1. GoodBytes
    20 Jan 2007
    1- Some people find MPC an awful video player.
    2- MPC doesn't provide thumbnail support in Windows, as it's a player
    3- DivX break Windows 7 64-bit codecs. Beside Windows 7 can already play divX (better too, taking more advantage of the GPU)
    4- As you mentioned, Shark007 can play odd video files.
  2. bleeper
    bleeper What's a Dremel?
    25 Apr 2012
    Which is the best player for perfect audio sync? I am absolutely fed up of VLC going out, normally about 15 minutes in. Totally breaks the viewing pleasure when I've got to start setting up a delay halfway through. Happens on DivX and MP4
  3. Deders
    Deders Modder
    14 Nov 2010
    I was basically asking if there were any that people preferred the quality of, not all codecs are the same.
  4. Deders
    Deders Modder
    14 Nov 2010
    What is your CPU, sound and graphics?
  5. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    WTH is wrong with VLC?
    I have never, ever had a problem with it - i think it's fantastic. WMP on the other hand I find awful!
    I am always open to new things however, so will try Shark at my next format. I don't believe it's an option on Ninite though? Which makes me less inclined to use it...
  6. bleeper
    25 Apr 2012
    CPU Pentium G620 2.6
    Memory 8GB DDR3
    GFX Radeon HD6850 (HDMI into Samsung 40 LCD TV)
    clean install of W7 on Crucial SSD 64GB, running files off second 2TB WD drive
    There is no stuttering, the video is perfect, it's just that on a large percentage of videos the audio drifts out of sync as mentioned.
    I was playing DivX files on my 300mhz Pentium without these issues so I am at a loss really...
  7. Deders
    Deders Modder
    14 Nov 2010
    Does this happen when you don't use HDMI?
  8. bleeper
    25 Apr 2012
    Ahh you have raised a very good point. Since this is my HTPC, I haven't tried... but I will! :blush:
  9. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I admit I like the thumbnail feature (Icaros) I had some thumbnails that came out in Vista and win7 beta but not win7 home premium, weird.
    So I added the file type to the exceptions and they appeared.
    Shark007 from forum......
  10. Deders
    Deders Modder
    14 Nov 2010
    So how come the VLC codec's aren't as good as the system codecs? VLC pretty much admits this in the options, at least it did. Maybe there isn't a difference between 007 and win7 codecs but codecs are always improving.
  11. Reg216uk
    Reg216uk Minimodder
    2 Nov 2011
    Ive always used K-Lite Video Codec packs...by far one of the best ones out there :D
  12. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
  13. happysack
    happysack goodateverthinger
    19 Dec 2009
    +1
    Me too, never not been able to play anything thrown at it.
  14. TehKrak3n
    TehKrak3n What's a Dremel?
    19 Jan 2011
    I have always used CCCP
  15. Ollie1807
    Ollie1807 What's a Dremel?
    12 Apr 2012
    MPC + CoreAVC has always led to good times, no problems here really, apart from subtitles randomly not working sometimes which I can deal with I guess.
  16. Deders
    Deders Modder
    14 Nov 2010
    Switched back to CPU decoding with VLC as HD content is still not as smooth when using the GPU.
