Storage Best way of wiping ssd's ?
Discussion in 'Tech Support' started by Yaka, 5 May 2016.
    Yaka Modder
    26 Jun 2005
    Im in the process of upgrading some lappys with small ssds to larger ones but what is the best method of wiping data off them?
    None of them are encrypted
    Thanks
  2. jinq-sea
    15 Oct 2012
    PartedMagic. The SSD wipe on there is my chosen tool.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    This. There is literally nothing else to suggest. Is there still a free version of Parted Magic though?
  4. Shirty
    18 Apr 1982
    You can still grab an older version, then use something like this to create bootable media.
  5. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    As said, PartedMagic is the go to on this one. Unfortunately, the last free version was still prior to displayport compatibility on Intel IGP... just something to bear in mind!
