Windows Best way to clone old OS on to new SSD
Discussion in 'Software' started by N17 dizzi, 5 Dec 2018.
  1. N17 dizzi
    N17 dizzi Well-Known Member
    23 Mar 2011
    I am still in the process of helping a friend's son get his PC up to scratch. He is running upgraded Windows 10 64bit on a spinning platter. The RAM is inadequate (has been and still being upgraded to 8GB). Currently it swaps out current memory use to the paging file leading to crippling performance. I bought a cyber Monday SSD so I can switch him over to something more modern.
    TL DR: Can anyone recommend software (or native in windows) that will clone his entire drive, saving us tons with a reinstall?
    I did a bit of googlefu but it seems a minefield of different opinions. I'd like some bit-tech insight if possible.
    Thanks
  2. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Macrium Reflect has a free version that should be able to do this no problem.
    N17 dizzi likes this.
  3. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I've used EaseUS Partition Manager free edition for this a few times, although if you're moving from a bigger to a smaller disk you'll have to buy the home edition for £18. Same size or smaller to bigger is available for free.
    N17 dizzi and silk186 like this.
  4. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I believe clonezilla is free still too, I've used that in the past
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    +1 for clonezilla, you can create a bootable CD or USB with it and it just works, no need to install any software etc.
  6. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    I've used Clonezilla pleeenty.
    If you're copying to a smaller or equal size SSD, reduce your partition size and move it to the beginning of the platter (use something such as gparted on a live Ubuntu or just windows disk management if the main partition is the last one).
    Then use Clonezilla without modifying the partition table (from this point on it's the same for copying to larger drives).
    Finally fix up the partitions, again with gparted or windows disk management.
  7. N17 dizzi
    23 Mar 2011
    Thanks a lot, very helpful. Glad I asked ^^
  8. silk186
    silk186 Canadian
    1 Dec 2014
    EaseUS Partition Master is the best I've found for managing partitions.
    I've never cloned a drive before so can't make any recommendations but I've seen a lot of recommendations for Macrium Reflect.
