I am thinking of moving up in the monitor world, from a 1680x1050 to 1920x1080 or 1920x1200 (or maybe higher...) and I want to know what my current VRAM utilisation is. Is there a utility that could record this? Specs in sig (gaming rig).
No idea, never used it. Does it? (...goes off to do his homework like he should of instead of being lazy...)
No, can't find anything on the MSI site about it either. Googles searches all seem to refer to old software circa 2008, is there anything newer (and that supports 64bit O/S's)? One of the reason's I ask is that I found this: http://www.overclock.net/10057086-post2.html. I am not confident that my current setup (768mb GTX 460's in SLI) will cope with either BF3 or a larger monitor.
Do you know how many posts/threads he has made? It'll be like looking for a needle in a haystack... Sigh - advanced search here I come.
I just found this post by PeteJ that shows Afterburner with a memory usage graph: http://forums.bit-tech.net/showpost.php?p=2500759&postcount=38. Is that an option on yours?
Gawd I am stoopid, I just scrolled down in Afterburner and both GPU memory usage graphs are already there... Ignore this thread completely, I'm being a moron...
I'm in trouble if I upgrade the monitor, 640mb VRAM usage with my current BC2 settings @ 1680x1050 - with vsync on as well. Looks like it will be both a screen upgrade and a GPU upgrade. I'm tempted by a brand new U2410 for £299 - a reputable seller on the evil bay. The problem is that I would probably need a GTX 580 to max out BF3 when it arrives.
u2410 is 1920 x 1200 @ finger's - I don't know how gpu heavy BF3 will be when it comes out (not my sort of game so I don't keep track) but I know those games seem to play well on nvidia card's, so I would suspect you'd be alright with a gtx 570 at that res, anything higher and a gtx 580 would definitely be called for.
