A/V Best way to plug 2 scart plugs into a tv with one scart plug??
Discussion in 'Hardware' started by couzo, 3 Sep 2003.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have a ps2 and a digi box that use scart sockets to connect to tvs. So I bought a £10 splitter for my tv from game so I could use both things, the thing is that when I use the digi box the sound iseven lower than before??? What is the best peice of kit to do what I want as I hate having to change the plugs over every time I want to use the other thing?
    Any ideas would be great thanks guys
  2. penski
    penski BodMod
    29 Aug 2002
    Moved to A/V :)
    And an amplified or shielded juntion box thingy is what would be needed I think... :)
    *n
  3. hk
    hk Powered By Duracell
    4 Jul 2002
    Yeah, you can get them from Argos (didn't bother checking if your in the Uk or not).
  4. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Something that switched would be best, rather than just a box that gives you multiple scarts from the single input.
    Any of the scart 'switches' here will do the job, you just have to decide on how much you want to spend and the level of functionality the switch has.
  5. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
  6. ginguskahn
    ginguskahn What's a Dremel?
    22 Apr 2001
    I agree with stew I have one of those for my xbox/cube/dreamcast and its great, u need to buy a decent scart cable to connect it to the tv tho.
    Means I can get an RGB signal from my xbox,dreamcast,cube and pro logic from my dc and gc, i dont have a pro logic II amp yet ;)
    I have 2 RGB and 1 Svideo scart on my tv and I still gotta use this splitter :p
