CPU best way to wrap amd cpu?
Discussion in 'Hardware' started by penryn 2 hertz, 28 Mar 2011.
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    :confused:hello i was wonderin what is the best way to wrap an amd cpu to ship so as not to bend the cpu pins ???
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    The way you sent the one I purchased from you arrived here fine, do you not have any more plastic cases with the foam in?
  3. bulldogjeff
    2 Mar 2010
    Raid a jewelers shop, chuck all the rings back and just keep the boxes...Simples:D
  4. penryn 2 hertz
    10 Jun 2010
    yes iv ran out of boxes
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Bit of low density foam works amazingly :)
  6. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Cardboard, or ridgid foam on both sides taped together (don't use anything soft that can sink into the pins and create pressure points). Add some packing peanuts round the sides if in a box, or if you're bold enough go use a bubble mailer, double up on cardboard.
    I once mailed a s775 P4 in a standard evolope surounded by thin cardboard, and it came out just fine on the other end. I had to pay an extra $.50 over standard postage, but it was still $7 less than a box
  7. Bloody_Pete
    11 Aug 2008
    I'd say go for foam that the pins can sink into as it'll hold them in place, I've had many IC's delivered that way with no issues...
