Apple Best Winamp equivalent?
Discussion in 'Software' started by riggs, 20 Jul 2007.
  1. riggs
    riggs ^_^
    22 Jul 2002
    So, I took the plunge and bought a Mac (not a new one mind you, went for a 2nd hand G4 12" PowerBook). I'm loving it so far but I'm missing one thing; a good MP3 software solution. I've been using Winamp (PC) for god-knows how long, and that's what I'm used to (a player as opposed to a library). I don't own an iPod, and can't see my self ever buying music from Apple, so that and a few other points put me off using iTunes.
    Can anyone recommend a good, stable Winamp alternative, with support for all major formats?
  2. RTT
    RTT #parp
    12 Mar 2001
    Honestly I can't recommend anything other than iTunes - I know it's probably not what you want to hear though. It'll take some getting used to though... :/
  3. cderalow
    cderalow bondage master!
    23 Jan 2002
    something besides iTunes for music playing on a mac!? BLASPHEMER!!!
    TBH, I can't think of anything off the top of my head at all... besides iTunes anyway.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    iTunes on a mac is great. The only other option I can think of is VLC? It is very basic tho!
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    there must be some widget or something flash based...
  6. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    iTunes is fine on OS X. If you can find an installer on the internet for version 6, rather than version 7, use that.
  7. steele
    steele What's a Dremel?
    17 Jul 2003
  8. Krikkit
    21 Jan 2003
    I'm surprised they haven't ported Winamp over to Mac - it's such a brilliant program, and a cornerstone of a lot of people's music on PC.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    In the same respect I wonder why Amarok (Linux) isn't ported to Windows. It owns Winamp in allmost all areas...
  10. riggs
    riggs ^_^
    22 Jul 2002
    Cheers Steele! From the screenshots, Toolplayer looks quite nice (small and simple) - may give that a try. I've already started using iTunes but tbh, I'm not convinced - there's something about it I just don't like, although I can't quite put my finger on it...
    There is actually an (unofficial?) alpha version, but apparently it's not too hot atm. Hopefully they'll stick with it and get a final version sorted eventually. *crosses fingers*
  11. steele
    17 Jul 2003
    I know what you mean about itunes, i feel the same. Think its a control thing, in that it tries to do to much for you and kinda leaves you out of any decisions it makes!! (or could just be I don't really know how to use it).
    Toolplayer is simple. And play is meant to be good for tagging
    Steele
  12. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    As a mac and ipod user, I can honestly say I could never use anything other than itunes, it's corny to say but "It just works"
  13. Amon
    Amon inch-perfect
    1 Jun 2007
    I 1UP this. I've started to use iTunes in the past few months and am beginning to like it. Very simple and easy to manage large audio collections--which are, hopefully, legitimate collections. However, my use of Winamp as an all-purpose media player is still unrivaled.
