Best Wireless Network Adpater
Discussion in 'Hardware' started by Noobkiller, 7 Dec 2007.
  1. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    What's one of the best wireless PCI network adpater right now. I'm looking for something under $100
  2. Krikkit
    21 Jan 2003
    PCI or PCI-e? I've got an abit Airpace card, which fits into a 1x PCI-e slot, and it's bloody brilliant, has a decent aerial even out of the box, and really easy to modify and add extra cooling to for a high-gain jobby. Very cheap too, and the software's great. :D
  3. computerman5
    computerman5 What's a Dremel?
    30 Aug 2007
  4. Shadow_101
    Shadow_101 Minimodder
    12 Feb 2004
    Are you going to be doing some network 'monitoring' ? Orinoco Gold comes highly recommended.
  5. phillj
    phillj What's a Dremel?
    18 Jul 2007
    I have always found Netgear to be the best wireless (for home) for routers and cards (as long as you use their software). Intel have always made good laptop wireless cards and great other network cards, so they may be worth a try.
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    $100 will get you any make/model you want... including wireless 'N' products (the fastest currently available - here in the UK at least)...
    such as the (ridiculously long URL'd!) Linksys WMP300N Wireless-N PCI Adapter... [​IMG]
