Graphics Between 7300GT with zalman fan VS 7600GT
Discussion in 'Hardware' started by tort, 28 Feb 2007.
  1. tort
    tort What's a Dremel?
    28 Feb 2007
    Hi there,
    i need some advise here. because i going to open a new cyber cafe shop. So now the problem is i need to chose a VGA card for my Cyber Cafe PC...The choice are--->
    1. Galaxy 7300GT with zalman fan 256MB ddr3 link is provide below--->
    http://www.bit-tech.net/hardware/2006/09/07/Galaxy_7300_GT/1.html
    2. Nvidia 7600GT ddr 3
    So i not sure which one suit for my cyber cafe. Please advise. Thanks you
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    good luck with the buiness, the question i ask
    ''Are you running games on these machines, or are they web surfing rigs?''
    If you plan on run games the 7600GT is the card of choice, however it all depends on the screen's you are using.
    TBH to set each machine up to play games @1024x768 will be fine for multi-player games in a cafe, and because of that id go for the 7300GT as there cheaper.
    And remember you buying more than one card, if you have 10 machines it will cost £500-600 for 10 7300GT's!
    You can double that for 7600GT's
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    If the computers in your cafe are not running games, you can get away with integrated graphics, saving you a whole lot more.
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Most cafes round here are gaming based. So...
    7600GT - Cheaper in the long run. ;)
  5. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    I agree. I use an evga 7600GT KO version, and I am extremely pleased with its performance.
  6. Austin
    Austin Minimodder
    16 Jul 2004
    :thumb: The 7600GT is a decent gaming card (unlike the awfully slow 7300GT) but the 7900GS and X1950Pro are a big step up and shouldn't cost much extra. Although it will mount up depending upon how many you need to buy don't forget you may get a small discount for buying a bunch of the same card. If they're for gaming then 7600GT is the bare minimum while 7900GS or X1950Pro will give that bit more longevity, esp if you keep the games up to date. If noise is an issue check which brand you buy or add-in the cost of after-market coolers.
  7. tort
    28 Feb 2007
    ya plan for gaming..so think will go for 7600GT
    then...if 7600gt better....so the XFX 7600GT better or the nvidia 7600GT better o?
    thanks for the opinion
  8. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The brand doesn't really matter, EVGA will let you upgrade them within 90 days by sending back the current card and only paying the difference between them. BFG and EVGA have good lifetime warranties, XFX has a double lifetime warranty covering you and one person who you may sell it too. That's my nVidia card manufacturer brand info for the good ones in the US, there may be others in the UK, but all 3 of these are there too.
  9. Austin
    Austin Minimodder
    16 Jul 2004
    :thumb: I wouldn't worry too much about which brand to buy, simply consider both the warranty and the cooling used.
