News Beyond Good and Evil HD confirmed
Discussion in 'Article Discussion' started by CardJoe, 30 Sep 2010.
  1. capnPedro
    11 Apr 2007
    You could try it on the game .exe file located in C:\Steam\steamapps\common\etc. etc., but you may have problems with Steam file verification restoring the unmodded version when you try to run it.
    You can manually force processor affinity by running the game, opening Task Manager, right clicking the game in the Applications tab and clicking on 'Go to Process', then right click the process and choose 'Set Affinity'. Make sure only CPU 0 is ticked.
  2. somidiot
    somidiot Minimodder
    18 Aug 2009
    No PC version? Lame, I'm going to get a GOG version then ...
  3. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    The original game was very good, unfortunately I lost my save game on the NGC and so never finished it. Downloaded it on steam but it runs like poo. Would actually buy a (working) HD version for the PC since it is my only gaming platform at the moment.
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    The HD title has nothing to do with the resolution, if you had read the article you'd know that they're just redoing the textures and soundtrack.
  5. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    I had it for PS2 and loved it to bits. I must have played it a gazillion times
  6. wyx087
    15 Aug 2007
    PC version please! they'd be crazy to skip the PC crowd......
    or this sequel might just be the game that made me buy a console.
  7. Er-El
    Er-El Minimodder
    31 May 2008
    Although PC versions of games - especially with last gen of consoles - the PC version has higher resolution textures and higher bit rate audio anyway. So it's probably just a port of the PC version to consoles.
  8. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    PC version, want!
  9. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Doesn't work... Never mind... I already deleted it, the sound is way faster than the images...
  10. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    A game like this which isn't a mindless cookie cutter shooter, you would think they would cater to the PC crowd.
    Oh Well!
Tags: Add Tags
