Modding bezeling an lcd
Discussion in 'Modding' started by skev13, 11 Mar 2004.
  1. skev13
    skev13 What's a Dremel?
    23 Jul 2003
    I was thinking of bondoing two 5.25" covers together, and then cutting for the lcd.
    how did you guys do it?
  2. Vash Theis
    Vash Theis What's a Dremel?
    5 Mar 2004
    bondoing
    i would really suggest a car site for that one. I would think you could basically apply it the same way. If anyone here works will with BOndo or F-glass they may be able tohelp. I tried my hand at F-glass, after twenty min with a little crappy face mask i was to fried to care. (i dont condone this, and basically havent dont any F-glassing since) but just make sure to use the mask. I always thought that bondo was used for like body filler, can it be shapped?
