Hi guys, my next project is in progress. I started it in December 2017 after i recieved a few parts of Cooler Master. My origins lie in the German Black Forest and i had the idea to merge a traditional german cuckoo clock with a multimedia PC. For that i made few scratch designs and how i could build the whole project but in the end i started to build free. Materials used will be: - 3/6mm plywood (first it's easy to work with, second it's cheap so errors might not hurt that much) - 3D printed stuff - Acrylic sheet for windows etc. Hardware is actually not decided yet. So far i got: - Cooler Master MasterWatt 500 - Cooler Master MasterLiquid Lite 120 - 2 Cooler Master MasterFan Pro RGB - a SanDisk SSD Plus 240GB The style i chose for the case is planed to have 2 different front designes - i hope this will work out. - First a half timbered house front style with a clock tower - second something more modern designed
Some pictures now of the actual progress: building the base on 6mm plywood - with 2 120mm holes for the fans. this is the basic design i ended up with first works on the front of the case - with 3d printed window frames. this is what it will kinda look like later. first time i use filler on 3d printed stuff (not printing that much) - left it unsanded because i want the frames to look shabby. painted them afterwards in burned umber, a dark brown acrylic color. and started to fill the areas between the frames with styrofoam (white acrylic to make it more look like a real wall.
long time no updates, i am sorry for that. trying to get you up to date now. the case itself did get a clock tower. temporary roof and hang the whole thing on the wall. after that worked out, i finally could install proper working hardware. but first i made myself a GPU holder. i needed a few tries to get this done. also i changed the roof with a dormer, so longer GPUs might fit too. After alot of tries i finally got roof-tiles that worked out the way i wanted the roof to look like. next steps will be finishing the roof, waiting for my arduino starter pack to get some mechanics running (atleast i will try, never done that)...
thanks. the clockwork had a cuckoo built in, but it was just one going up and down. my plan is to abuse the 1/4hour wheel to get some effects going with an arduino and a servo...maybe this will include a cuckoo, but i first have to figure it out.
