Windows BF2 Problems
Discussion in 'Gaming' started by Neema5, 8 Nov 2005.
  1. Neema5
    Neema5 What's a Dremel?
    8 Nov 2005
    Hey guys i need your help. I just build my first computer.
    Specs:
    Intel Pentium 820 D Processor
    1GB of corsair
    250GB 7200rpm SATA drive
    ATI Raeon X800XL 256MB PCI-E
    Onboard Intel audio.
    I have all the latest patches and everything else. I just got BF2 a couple days ago and it was working fine at first. The only problem I had is my headset doesn't work. Just yesterday I went to play it and after it loads the map the screen would go blue and freeze. I updated my drivers and such but now when the map loads it exits the game and goes to the desktop. I can't figure out how to fix this. I've already uninstalled and installed the game. I've tried everything i can think of but it still won't work.
    Got any suggestions?
  2. PHILIP1193
    PHILIP1193 a Self Confessed HP Server Lover!!
    8 Dec 2004
    well i don't know if you already have but anyway .... update yr x1800xl driver to eth 5.10a/b version, the drivers for the new ati cards are shoddy to say the least not unleashing eth full potential of yr card.
    As far as the exiting goes, i think you need to make sure you got the 1.03 patch of bf2 also make sure punkbuster is up to date, also try googling bf2 problem with Intel 820 ( random guess on what to Google ) but see if any one has had probs
    sorry bout no definitive answer but try some of the above if u haven't already
    Phil
  3. poot
    poot What's a Dremel?
    11 Nov 2005
    had lots of blue screen crashes with my newly built pc.
    fixed it by using older video drivers
    the latest drivers were what caused the crash
    alos i had audio cracking.
    again solved by using a specific old driver rather than latest
  4. Vonpo
    Vonpo What's a Dremel?
    9 May 2005
    I actuly have audio cracking as well ... but I use an onboard sound card. So if I found an older driver for my sound card will it stop?
  5. westie
    westie What's a Dremel?
    31 Jul 2005
  6. poot
    11 Nov 2005
    my sound was actually onboard sound. i think realtek drivers ac97 drivers.
    it was one specific year old driver that fixed the dam crackling
  7. EarlGrey
    EarlGrey What's a Dremel?
    17 Aug 2005
    Setting the audio to use Software rendering should solve the crackling (if it is set to Hardware rendering).
  8. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    yes that helps, or just de frag your hard drive. set it to software,
    ahh the joys of x-fi hehe :rock:
