Graphics BF3 memory issue
Discussion in 'Tech Support' started by Jeevus, 29 Oct 2011.
  1. Jeevus
    Jeevus New Member
    6 Sep 2009
    Hey guys, hope you can help. Running BF3 on the system in my sig and with graphics settings on high and I kept crashing out with a DirectX error message (see pic).
    I then took AA, motion blur and HBAO off and although it happens less, it still happens. I have the latest Nvidia driver, the GFX card is at stock settings and when in game the card doesn't go above 80 degrees C.
    Any ideas?
  2. GoodBytes
    20 Jan 2007
  3. Jeevus
    Jeevus New Member
    6 Sep 2009
    Thanks but it said I had a newer or equivalent already installed.
  4. GoodBytes
    20 Jan 2007
    Well from your annoying, impossible to read pictures, it looks like you have very old drivers.
    Get the latest drivers from Nvidia website.
    Be sure to go under Custom, remove anything that you don't need/use, and check the box to do a clean install.
  5. Jeevus
    Jeevus New Member
    6 Sep 2009
    I updated to the latest driver two days ago and when doing so removed the old one before hand.
    It was strange though after I ran the DirectX installer you linked I managed to play 3 full maps without any problems. I guess I will see how it goes.
  6. AceRimmer77
    AceRimmer77 New Member
    27 Aug 2011
    I had that cash once with battlefield as I was joining a server, only happened the once and has not been an issue since. I have everything updated as well.
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Does look a very odd error.
    It could be a bug in the game, causing a texture to either be far too big, or something that's wrong with a catch block in the error processing code.
    Could also be a bug with the drivers and the game talking to each other, causing the game to think you've not got enough VRAM.
    In the BF3 general thread, there was talk about people with 560ti cards having problems, what these problems are I don't know.
  8. Jeevus
    Jeevus New Member
    6 Sep 2009
    I was playing most of the weekend and it only happened a further two times. I guess it will be something I have to accept and hope it can be ironed out with an update.
