Modding BG micro VFD in LINUX
Discussion in 'Modding' started by Drastik, 15 Sep 2002.
  1. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    i have a bgmiro vfd and i want ti use it in LINUX is there any software
  2. Cheese
    Cheese Doc
    6 Oct 2001
    I don't use Linux and I don't have a BG Micro VFD, but I'd say your best bet is http://lcdproc.omnipotent.net/download.php3 - LCD Proc.
    It should certainly work with the display wired up to the parallel port and if it doesn't have serial support already i'd appeal to it's author (led to believe he's a nice chap) :)
    Cheers,
    Rob.
  3. Drastik
    10 Jan 2002
    my vfd is both paralell and serial but i have it wierd for serial atm
  4. Cheese
    Cheese Doc
    6 Oct 2001
    Yeah I know, the controller on that VFD is pretty nice :) So either wire it parallel or try to make it work serially in LCD Proc (by pestering the author if need be), I think those will be your only options though I could be wrong (happens far too often ;)).
    Cheers, hope you get it sorted,
    Rob.
  5. Drastik
    10 Jan 2002
    i will try lcdproc i hope it works. i saw a review about a some graphical lcd on this site and i dont know where or what it was.... do u have any info on that?
  6. bmph8ter
    bmph8ter What's a Dremel?
    12 Jun 2002
    http://forums.bit-tech.net/showthread.php?s=&threadid=12398 Has all the info you want. Hope LCDProc will work on the BGMicro VFD (is it the huge one of [H]ardOCP fame?). If it is, there is a HUGE thread over there that may give you a bit more of a leg up software wise. Good luck!
  7. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    have u got a link for that VFD? I am v interested.
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Pretty sure they've stopped selling them, the old link I had for them no longer works :(
    let me know if you find em, want the link for my faq.
    Cheers,
    Rob.
  9. linear
    linear Minimodder
    5 Oct 2001
    OK, maybe I can weigh in with a couple things here...
    BGMicro seems to have sold out of them. At least they don't list them any longer.
    Second, in real operating systems, serial ports are super easy to write to. Using whatever means necessary, just write to the serial port.
    FreeBSD example:
    Code:
    echo "foo" > /dev/cuaa1
    Just substitute the name of your serial port device as appropriate.
    All you get from LCDproc is a tool to monitor a bunch of stuff. Easily done with shell scripts, perl scripts, etc.
  10. Cruelinios
    21 Jan 2002
    Damn, well Ill do the next best thing then, ill invert my LCD ... :D
  11. Drastik
    10 Jan 2002
    if you are looking to buy one i have 1 for sale in custom enclosure wired for serial ready to go........................ name ur price
