Modding Big (ish) Reservoir Perspex
Discussion in 'Modding' started by Modsbywoz, 5 Mar 2010.
  1. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    I'm just about to order my perspex for a large reservoir, however, i think i've read this somewhere ( either that or i dreamt it ) that you can only build them so big due to the heat expansion etc?
    Can someone shed some light in this area?
  2. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I haven't used perspex per se and hence don't know if it is cast or extruded, but with cast acrylic, people make aquariums out of this. I doubt you would have a problem making any res for use with a PC from this. How large is this going to be?
  3. Modsbywoz
    14 Oct 2009
    hmmm,
    approx the size of the res in Project Flow... so doubt it will be a problem now, im going to read his project log now to find out...
  4. Cheapskate
    13 May 2007
    Thermal expansion can pop any size reservoir with enough buildup. You either need a way to relieve the pressure, or build heavy. I've added one of these to the air pocket of my loops. They also make a good leak indicator. If the accordion decompresses while not running/cool, you have a leak somewhere.
