Case Mod - In Progress Big Lian Li. 100% Complete. FINAL PICS.
Discussion in 'Project Logs' started by lowfat, 14 Jan 2014.
  1. Nikozii
    Nikozii What's a Dremel?
    29 Oct 2013
    This.. :jawdrop:
    Was that block like this before polishing?
    I got that block. I've been wondering should I polish it or not. But if it comes like that I must do it!
    Also, where you took those thumb nuts? My block camed with ugly ones. :D
  2. lowfat
    lowfat Minimodder
    4 Jul 2013
    Yes that is what the block looked like before. I spent a lot of time wetsanding and polishing the top. I also have polished the nickel as well. The thumb screws are originally from a Supreme HF. They were originally silver but I have plasti-dipped them black.
    Then yesterday morning I 'finished' w/ the cabling.
    I nibbled myself a false floor and the frontside 5.25" bay cover.
  3. Nikozii
    29 Oct 2013
    Oh, nice. I must polish mine as well now. :D
    Did you polish bottom of acryl too? Or is it "clean" already?
    You got awesome cable management too. This build is so clean. :)
  4. lowfat
    lowfat Minimodder
    4 Jul 2013
    I polished everywhere. I wet sanded till all machine marks were removed. Then polished. That way it looks clear as glass.
  5. Nikozii
    29 Oct 2013
    Yep. Awesome, thanks! :thumb:
    I'll try with 600 - 800 - 1000 - 1200 papers. Maybe 2000.
  6. lowfat
    lowfat Minimodder
    4 Jul 2013
    I would only personally do 1000, 1500, and 2000. Anything lower and you'll likely sand off the circles.
  7. Nikozii
    29 Oct 2013
    Okay. Big thanks for you again! :)
  8. lowfat
    lowfat Minimodder
    4 Jul 2013
    Nibbled a new 5.25" side cover. This one is a bit larger to fit the radiator a bit better. Also mounted the false floor properly.
    Then I mounted the front radiator.
    A few pics w/ the hardware reinstalled.
    The last few days I have been attempting to use the Monsoon mandrels. It hasn't been going so good. I went through 8 feet doing this single run and it still isn't right. It is 2-3 degrees off. :(
  9. lowfat
    lowfat Minimodder
    4 Jul 2013
    First draft of the acrylic done. I will redo a few bends after I buy more tubing.
  10. lowfat
    lowfat Minimodder
    4 Jul 2013
    Have to fill down these standoffs at some point to flush them.
    A few macros of some brass filings. :eyebrow:
    Mounted the pump properly. Also shows off the paint job on the Koolance pump body. Will need to give it a touch up before final product. Looks much better than the stock black nickel IMO.
    View from the backside of the radiator.
    Got bored. :yawn:
    Finished sleeving the fan controller and power/reset cables.
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    That is a gorgeous build, Sir! This just inspire me to do something with my goodOl' PC-V1200.
    I keep a very close eye on this.
  12. lowfat
    lowfat Minimodder
    4 Jul 2013
    Thanks. The PC-V1200 is an awesome case. One of my all time favorites
    Dyed my radiator fans.
    Finished sleeving the top rad fans. Then reinstalled the system back in the case.
    Was able to power on the system last night. Had a few issues at first but after resolving them she works great.
  13. lowfat
    lowfat Minimodder
    4 Jul 2013
    Drained the water and refilled the loop w/ the blue coolant.
  14. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking very minimalistic and clean. Top notch! :thumb:
  15. Nikozii
    29 Oct 2013
    Blue coolant fits really good on this build!
    I think this would look awesome with fully black case. But this is looking good as well. :)
    Have you think about some cover on front rad? Or painting it again? There seems to be couple pretty big scratch.
  16. lowfat
    lowfat Minimodder
    4 Jul 2013
    Thanks. :D
    The case will be powder coated black once I finish doing all the necessary modification.
    Likewise the radiators, pump body, reservoir body will all get touchup paint jobs when I take the system apart.
  17. jamsand
    jamsand Minimodder
    21 May 2011
    Your cable management makes me want to cry with envy
  18. Nikozii
    29 Oct 2013
    Oh, that sounds amazing. Looking forward on it! :)
  19. lowfat
    lowfat Minimodder
    4 Jul 2013
    Decided I don't like how loud the DDC is in this system. So I ordered a PWM D5 w/ EK top and casing. They arrived today.
    Tomorrow I'll polish this up. It is so much bigger than the DDC top. It should look rather good when cleared.
    And the pump casing. I already did a 5 minute polish w/ some Autosol.
    I polished & sanded up a couple of EK Supreme HFs. Don't think I'll use either of them for this build since I would like my blocks to match.
    The polished one w/ a bunch of various Mayhems coolants I have mixed up.
    And then one that I frosted.
  20. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    are you gonno "frost" the GPU block too ?
