Modding Big Spark
Discussion in 'Modding' started by M_D_K, 7 May 2003.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I just fitted my fan bus and a big spark came off it as i was putting it in the case then the system died.
    I've mounted my fan bus in a steel face plate so i prosume that its live but how can i stop this from happening so that i cna mount it in my case
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Maybe try turning off the computer, even though it means that you will be away from bit-tech for a minute or two.
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    the computer died so i turned it back on and here i am trying to work out how to mount the thing i need ideas
    would putting the piece of think plastic behind it work or are the switches them selfs live. Its a pcmods one bought it a while back
  4. bard
    8 Mar 2003
    How about turning the computer off, mounting the fan bus, and turning the computer on again?
  5. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    tried that it shorts out
  6. bard
    8 Mar 2003
    Then you'll have to look for places where the + wires can be touching a ground wire or the computer chassis.
  7. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    yup sounds like you have a short somewhere :miffed:
    Meblin
  8. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    i know i got a short but how do i sort it its the fanbus but the only things that touch the mettel are the switches :-\ so i dunno what i cand o
  9. Meblin
    5 Mar 2002
    how many switches have you got?
    which terminal of the switch is connected to the switch housing?
    This terminal needs to be gnd and the outher your 12V/7V/5V
    Make sure all the switches are wired the same
    Meblin
  10. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    if the switch is of the "metal arm" type... (or whatever you call it) the center connection is often (specially on the cheap ones) in contact with the arm itself... this is becase the arm is metal.. and it as a little tap that just slides over the "contact plate".. (hard to explain.. but believe me.. i have taken o few apart... :dremel: )
    if the switches is in contact with th positive (as i assume it it because it probably switches between 12 and 5 volts or something) then the whole matel boty of the swich becomes connected to positive... negative is often on the case... with the plastic front you are ok cus' this insulates.. but with a metal fron you make a connection...
  11. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    yeah i tested the switches with a Multimetre and 3 of them are ok and 1 of them is 12v ive go 4 switches on it
    It like th 6 switch on on the site but with 4 :D its well old now dug it out my box
  12. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    The PCmods ones shouldn't short unless you plugged all six fly leads in and not into six fans? Like ours the 3 pin male KK connectors are live and can short on case.
  13. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    but one of the switches is live ( i had to talk him thru using a dmm) but its probably just a bblob of solder or a ded switch
  14. loply
    loply What's a Dremel?
    26 Dec 2002
    Carefull dude, short the PSU one too many times and it wont come back alive.
  15. Dark_Blender
    Dark_Blender What's a Dremel?
    3 Jan 2003
    Is it possible that somewhere a live wire is touching your case and when you put it in, it completes the circuit?
  16. Oclocker
    21 Jun 2001
    Yes - thats what I was getting at but eliminating the possibilty of the live flyleads being a problem..
    would take a look for a minimal charge as a hexus user?
