Bigadv server problems 128.143.231.201
Discussion in 'bit-tech Folding Team' started by Ben Lamb, 30 Sep 2012.
  1. Ben Lamb
    Ben Lamb What's a Dremel?
    2 Sep 2012
    Looks like there is a problem with bigadv server 128.143.231.201. I have just lost a juicy fat 8102 with the error "server does not like work unit, dumping" :wallbash: Kasson is working on the problem, thought I would let you guys know incase you get the same annoying error.
    edit - two more 8101s down the toilet and I was going for world domination too - my evil plans in tatters.
  2. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    Seems OK this morning, uploaded a 8101 at 0600HRS.
    No it didn't :wallbash: - server reports problem.
    Same server!
  3. Slowlemon
    Slowlemon What's a Dremel?
    17 Apr 2012
    Hi Ben
    I lost an 8101 this weekend, I thought it was a problem at my end. I just checked and it was the same server you had problems with. I have just successfully uploaded a 6901 but that went to a different server.
  4. Ben Lamb
    2 Sep 2012
    It looks like the problem relates to bad work units that were asigned on the 28/29 of oct. The system should be ok now but it hasnt been confirmed and Pande group have been less than helpful locking the relevant thread on the forum and not confirming if the issue is fixed or what it actualy is !
    I am giving bigadv another go to see if it is ok now, very unhappy with Kasson and the Pande group as their attitude towards donors is poor on this occasion. They need to get their systems in order and have some appreciation of the time and money used by donors instead of viewing them as pests.
  5. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    Looks like I lost a P8101 yesterday also :(
    Sent from my BlackBerry 8520 using Tapatalk
  6. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Very well said mate, totally agree! I lost 2 x 8101's which im annoyed about which is almost 3 days worth of constant folding down the drain grrrrrr :wallbash:
  7. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Ditto :duh:
  8. kirk46
    9 Jun 2012
    picked up some P6901's since the server problem only 2-4k more ppd than the P8101.... i expected more...
    but ive just got my first P8102 and ppd is 140k :D compared the 96k ppd for the P8101
  9. Ben Lamb
    2 Sep 2012
    The server problem is fixed now apparantly it was an assignment to work server communication problem 8102s are great was gutted to loose one with the server cockup.
  10. kirk46
    9 Jun 2012
    think ive lost the P8102 WU :(
    i should have got 240k for that WU but i camt see it in my folding stats :wallbash:
  11. kirk46
    9 Jun 2012
    just looked in the terminal the P8102 got to 24% and then this came up......
    Program Gromacs, VERSION 4.5.3
    Source code file: /vspm58/VM/fah-converted/mnt/fah_windows_build/LinuxBuilds/gromacs-4.5.3/src/mdlib/pme.c, line: 534
    Fatal error:
    1 particles communicated to PME node 10 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
    This usually means that your system is not well equilibrated.
    For more information and tips for troubleshooting, please check the GROMACS
    website at http://www.gromacs.org/Documentation/Errors
    also unstable machine appears later on in the terminal
    but the system churns out other bigbeta WU without issues?
  12. Ben Lamb
    2 Sep 2012
    Bummer - hate it when this sort of stuff happens.
