Motors Bike smash
Discussion in 'General' started by ouija, 23 May 2004.
  1. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Meh..... I won't go into details but here are some pics for you to cringe at. Right corner, swerved to avoid padestrian, braked, up grass verge, thrown off, bang.
    Side fairing
    Close-up
    Rear seat
    Top fairing
    Nothing that can't be fixed, and I'm fine which is lucky.
  2. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    I saw a car change lanes right in front of a motorcycle. He braked but still took off her side mirror.
    All because there was some warning to call the police if you see a particular vehicle.
  3. babychaos
    babychaos What's a Dremel?
    12 Apr 2002
    The fairings gonna be expensive...good advert for mushrooms (got my first full size bike in January, crashed on a wet Friday 4 weeks ago, and its still in the garage because every other biker did the same thing...)
    So long as you walked away everything else is fixable... :thumb:
    BC
  4. Lithium
    Lithium super spunk
    26 Jul 2002
    Ouch matie, bet it gave ya a fright. The main this is that you are ok :)
  5. penski
    penski BodMod
    29 Aug 2002
    Owch...
    At least you're okay, dude.
    *moves to Motors*
    *n
  6. ouija
    10 Nov 2002
    Yea, I'm absolutely fine. A bit stiff and a couple of bruises and friction burns but that's a damn sight better than having to pick gravel out of my leg for weeks. Without my leathers, my hip and elbow would have been shredded to the bone.
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I used to love mucking about on my trials bikes years ago
    But was always too scared to get a road bike, too worried about how unpredictable other drivers were.
  8. jonesie
    jonesie What's a Dremel?
    24 Nov 2003
    Why do people not wear leathers? Damn stupid. Having said that, cyclists reach speeds of 30 mph and (myself included) wear no body protection, which is a bit stupid too...
  9. ouija
    10 Nov 2002
    I have been mocked at wearing a full £400 leather suit with armour for my bike, since it is only 125. Seeing as it will do just over a ton, and 2-stroke bikes nowadays are a lot faster than they used to be, I think I'd rather wear them. 125cc or 1000cc, you fall off at 50mph, you're going to do the same damage to yourself.
  10. RTT
    RTT #parp
    12 Mar 2001
    Ouchy - glad you are alright though. Time to repair and upgrade? :D
  11. Ubermich
    Ubermich He did it!
    21 Jun 2002
    One word: bondo :D
    Glad you're alright.
  12. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Glad you're OK ouij ... Looks like a lowside yea? And is that a small dink i see in the tank? bummer if it is :(
    Good job it wasnt a highside .... they really smart. I havnt ridden for a few years but i had my fair share of crashes, mostly my fault, but the number of cars that tried to knock me off (especially one volvo driver in particular - deffinately on purpose but i got my own back after checking my pants for stains) its just scarey.
  13. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    ouch, glad your ok dude! cant go wrong with leathers!
    btw thats an RS125 isnt it? im thinking of getting into this whole motorbiking malarky and have been eying up the little aprilias, would you recommend it?
    cheers,
    RoB
  14. ouija
    10 Nov 2002
    fivecheebs, as I went along the grass verge and hit the mound I was thrown off the top of the bike. As I rolled along the road and banged my head, all I could hear was the bike landing on its side and sliding across the road. Took me a few seconds to get back up again, then it was all about the bike and the damage.
    Yes, Phase. Superb bike for a 125. Will do over a ton de-restricted and there's so much you can do to them.
  15. phaSe
    4 Jul 2002
    cheers...perhaps time to start looking a bit more seriously methinks! :D
    RoB
  16. ouija
    10 Nov 2002
  17. clumsybiker
    clumsybiker What's a Dremel?
    29 Apr 2004
    Glad you ended up ok dude. Bike crashes can get nasty.
    Here's what I ended up with after bouncing a Fireblade off a car last year. After the impact, the bike and I parted company, and it went underneath a second car. :wallbash:
  18. ouija
    10 Nov 2002
    Ouch, nasty! As long as you're alright thats the main thing isnt it.
  19. RTT
    RTT #parp
    12 Mar 2001
    Poor 'blade :blah:
  20. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    Nothing that can't be buffed out. :p
