Windows .BIN/ .CUE to .ISO ((HELP!))
Discussion in 'Software' started by djwc101, 7 Jun 2010.
  1. djwc101
    djwc101 What's a Dremel?
    6 Jun 2010
    Recently download a sound sample pack and after extracting the .rar it gave me .bin & .cue file. I tried converting just the .bin to an .iso using MagicISO but it keeps giving me an error message? :wallbash:
    Is there a proper way to convert .bin/ .cue files to an .iso or do I maybe need to repair the .bin file??
    Thanks in advance!
  2. raxonb
    raxonb Minimodder
    5 May 2009
    Try mounting the cue file in a virtual drive (like Daemon Tools) and then use MagicIso to make an image from the virtual CD.
  3. Krikkit
    21 Jan 2003
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    :wallbash: :D
    AFAIK, you have to use the BIN and the CUE file together; try opening the CUE file rather than the BIN file (the CUE file will just point to the BIN file anyway). Alternatively, you could open it in Nero and get that to create the ISO file instead.
  5. Krikkit
    21 Jan 2003
    Oops. If MagicISO refuses it could be a broken .bin/.cue...
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    winrar has a test you can run to verify.. do that to the rar and if it fails- try downloading it again
    you can even get rid of the cue file in my experience, just need the bin
  7. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    .CUE files are plain text, try opening it in notepad and seeing it is has a directory path in it. If it does, remove the path and leave the .BIN filename only and place the .CUE in the same directory as the .BIN.
