Apple .bin files trying to be opened with excel?!
Discussion in 'Software' started by exavier412, 14 Oct 2005.
  1. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    somehow my default program for opening up .bin files got changed to excel. and now excel is trying to open them and obviously that is not going to work, so how can i change it back so that these applications will open correctly? thanks
    -DyLaN
  2. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Right click on the file
    Go to Open With
    Select Choose Program
    Find the right program you want
    Be sure to check "Always use the selected program to open this kind of file"
    I dont have excel installed right now, but what you might want to do is open up excel and go into the options. Find where it lists the associated files and uncheck .bin.
  3. exavier412
    15 Jan 2004
    no thats not the thing. i know that .bin should be an executable file, but i cant execute it because for some reason excel tries to open it.
    all the programs i try to download from websites online (yahoo messenger, aim) are attempting to be opened by excel, and not docking the program so i can install it. what do i do?
  4. DivineSin
    23 Apr 2004
    Are you sure there .bin files and not .exe files? If there install executiables that you downloaded (yahoo, aim) there .exe and not .bin.
    Your going to have to go through the excel options and try to find an option to change what files excel associates itself too. Or you could uninstall excel, then reinstall it after you've installed yahoo messenger and aim.
  5. exavier412
    15 Jan 2004
    those file types i mentioned are the ones being downloaded. i dont think apple computers (mac OSX) can open .exe files
  6. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    highlight a bin file...
    press "command(apple key) + i"
    You see a check next to "open with:"
    click on it to expand it...
    and then select the app...
    if it's a OS X .bin file.. then usually it's compressed and can be opened with stuffit.
    P.S. @ DivineSin... he's posted on the apple forums.. so i'm guessing he wants to know apple realted answers... you've been describing steps to fix it for a windows machine lol!!
  7. DivineSin
    23 Apr 2004
    :wallbash: :wallbash: Really wish i would of saw that this was posted in the apple forum. Disregard my help.. :wallbash:
    Really gotta check that when i see whats new under new posts.
