Scratch Build – In Progress Biohazard Computer Case Mod-Back Panel-I/O shield 10/18
Discussion in 'Project Logs' started by BLUEHORSESTUDIOS, 25 Apr 2010.
  1. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    Thanks Ziip, I wasn't sure about the green LEDs but they turned out better then I thought behind the smoke acrylic.
    I got started on the roof line LEDs , and more panel details.
    As for the hardware, I'm not sure if I should bite the bullet and go with the E.E CPU or something more affordable like the 950 and use this as a upgrade path to the E.E.
    Thanks for your support.:thumb:
  2. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Ooooo, decision time. surely the 950 would suffice for pretty much anything, unless you're going to running something incredibly CPU intensive.
    I just want to see this behemoth all together and fired up!
  3. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    WOW... Just... WOW... Speechless! :jawdrop:
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Ok, couple of questions and suggestions:
    1. Why didn't you try to get the hardware sponsored? Im sure lots of brands would love to get involved in this insane scratch build?
    2. The new Sandy Bridge platform should be quite good - you can OC an i7 2600K to more than 5 GHz - on AIR! Imagine what you can do with watercooling....
    So, why not wait a couple of months with getting the hardware? If there's one thing I've learnt from my own project then it's to wait with getting the hardware until the case is almost complete - unless you risk ending up with rather obsolete hardware. Ok, I'm sure the hardware you listed won't be anywhere close to being obsolete in a couple of months, but what if your time plan doesn't hold up? Unforeseen things CAN occur, y'know?
  5. BLUEHORSESTUDIOS
    19 Apr 2010
    Ya I agree with you NutMan, the sandybridge platform does offer a lot of upside. I rebuilt my pc and a friends this year with the x58 sabertooth and was able to get a very stable 4.0 overclock on this board. It really was a hard choice, but it came down to the reliability of the x58 platform .
    As for sponsorship, I'm seeking that for my CPU, powersupply and watercooling.
    Bill Owen gave me some great advice about how to go about that and I'm hoping something comes from that soon.
    I was going to wait til the entire case was completed to get my hardware but really can't afford to fork out $2500-3000 in one shot. Buying my specs when I had some extra cash was easier on my budget.
    Heck.. Hardware become obsolete so fast these days anyways.
  6. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Been watching this one for a while now, great to see it nearing completion :thumb:
    Now then, can all the GW nerds from the thread in general come over and have a game of Necromunda in it? :D lol
    Absolutely love this mod.
    [ZiiP] NaloaC likes this.
  7. [ZiiP] NaloaC
    9 May 2008
    Hehehehe, I would agree there Throbbi. This thing screams a necromunda match. :D
  8. DeadP1xels
    30 Nov 2009
    So amazing i love watching this
  9. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks Throbbi
    Thanks Ziip
    I don't care what you what we play, barbi dolls for all I care as long as this thing fires-up and runs wells ..lol.
    Warhammer, gijoe, starwars , all nerds and beauties welcome.
  10. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks DP,
    When are we gonna see another great build from you?
  11. Torin
    Torin What's a Dremel?
    8 May 2011
    wow really love that cant believe missed this build
  12. DeadP1xels
    30 Nov 2009
    Ha! hopefully soon
    Im been planning a few things something a bit different something that will hopefully look good :p
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Everything and that hardware list looks good Ron! Lookin forward to the next updates :thumb:
  14. BLUEHORSESTUDIOS
    19 Apr 2010
    Biohazard Computer Case Mod Update June 6th
    Blue Horse Studios is proudly sponsored
    BY
    On todays update Im going to finish up all the raw construction on the front panel and spray my first coats of primer.
    I started off today by defining the roofline with some generator towers.
    Doing a dry fit to check for any gaps within the seams of the two structures.
    Now I want to build out on this structure by adding antannas and support columns.
    Here Ive added the tower to the main structure and applied two coats of primer
    Now I'll begin working my way around the roofline adding more detail pieces.
    With the right side completed I'll now construct the left side.
    Im applying modelers putty within the seams and doing a light sanding before and after my first coats of primer.
    More model pieces help define and detail the structure.
    Now I'll spray my final coats of primer and prep for paint.
    Heres a final look at the structure before I go into all the paint and weathering details.
    And a look with the LEDs illuminated.
    On my next update I'll finish the paint, construct the motherboard tray , I/O panel and reveal some of my hardware choices.
    Part 12 of my video worklogs are in final edit and will be posted in a few days.
    Stay Inspired and Keep Creating!!
    Blooddrunken likes this.
  15. [ZiiP] NaloaC
    9 May 2008
    Absolutely incredible work so far. :)
  16. Nutman
    21 Oct 2008
    Looks sweet, as always. How about some persons inside the control towers?
  17. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This is a real piece of art! Mod on buddy this is awesome!! :)
  18. alain-s
    alain-s Minimodder
    12 Jan 2011
    +1
  19. DeadP1xels
    30 Nov 2009
    You really have an eye for this biohazard stuff you just seem to get the whole theme working all the way through
  20. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    absolutely stunning work. +rep and 5 stars :thumb:
