Bios Flashed - PC doesnt work?! :( Urgent help! :(
Discussion in 'Hardware' started by AlexB, 8 Apr 2006.
  1. hitman012
    hitman012 Minimodder
    6 May 2005
    Try bumping up the HT, chipset and RAM voltages by .1V or so each (careful not to void the RAM's warranty by exceeding specification if it's at fault here).
    DFI problems are a bitch to sort out. It might be worth trying an 8 or 24 hour clear if there's no solution in sight - that's solved out a number of problems before. It's also possible that the newer BIOS has changed some memory values that were previously fine... what are the major settings that you're using? It ight be worth loosening the timings and putting it down to 2T to try and get the RAM recognised.
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    are you sure you used the right file when you flashed your mobo, and not one for some random motherboard?
  3. hitman012
    6 May 2005
    If that were the case, it probably just wouldn't start at all. Thinking about it, I did know of someone who did that... needless to say, a replacement was on the cards. AlexB can rest assured that the problem is quite that bad :)
  4. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    I'll try a 24 hour clear. Cheers guys.
  5. TMM
    TMM Modder
    12 Jan 2004
    Bah the problem is with the bios not being compatible with the memory. clearing the bios for 24 hours or even doing a monkey dance won't fix it.. believe it or not :eeek: :D
    If you can boot stabily into windows with one stick, do that and flash to a different bios. :thumb:
  6. AlexB
    22 Dec 2005
    which bios then?
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    The BigToe modded 702 BTA has served me well here, that might be worth a try :)
  8. AlexB
    22 Dec 2005
    I'll google it - thanks.
  9. AlexB
    22 Dec 2005
    Success! I used 704-2BTA - as I couldnt find the 702. Everything works properly now :D
    Cheers for all the help
  10. kenco_uk
    28 Nov 2003
    The beginning of this thread had me hooked, the middle wavered a bit, but the ending brought a tear to my eye. Well done youz guyz :)
