bios problem
Discussion in 'Hardware' started by doodle, 5 Nov 2002.
  1. doodle
    doodle What's a Dremel?
    19 Sep 2002
    I recently updated my bios in an attempt to fix the problem of my hard drive only running in pio (to no avail). Now every time I restart my pc it crashes and I have to reset it manually. It does this in winxp, 98 and dos and even when saving bios settings. The system spec is MSI kt266 pro 2 ver 3.0, 256mb ddr, geforce gts, maxtor 30gb (new).
    Doodle Bug
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Did you clear the cmos after the flash ?, if not try that.
  3. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Have you tried reflashing to the old BIOS to see if that solves the problem?
  4. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    ill answer that one (i know doddle). it was doing this before he flashed the bios but it has just got a lot worse now.
  5. doodle
    19 Sep 2002
    Thanks will give those suggestions a try, maybe at the weekend (these things have a habit of going wrong and I need the thing for work).
    Doodle Bug
