Bios update
Discussion in 'Asus UK' started by bulldogjeff, 11 May 2015.
  1. bulldogjeff
    2 Mar 2010
    I have tired everything to use the bios update on the AI suite and all I get is connecting to server.. 2 hours later still the same. This isn't a one off, been over a few months anytime I have tried. Any one care to shed some light on to why this might be?
  2. bulldogjeff
    2 Mar 2010
    Any one ?.. 84 views and nothing
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    What board is it mate
  4. Big Elf
    23 Apr 2009
    They probably changed or closed the server location. There's quite a few hits on google with people having problems accessing it. Doesn't work for me either.
    bulldogjeff likes this.
  5. bulldogjeff
    2 Mar 2010
    Ah so it's not just me then. I did at one point think it was my mobo playing up. Then changed boards and still the same.
    At least that makes me feel a bit better.. Thanks dude.
  6. Kovoet
    26 Aug 2009
    What board is it
  7. bulldogjeff
    2 Mar 2010
    Tried it on the Gene and now on the maximus V formular.
  8. Kovoet
    26 Aug 2009
    Might have it on a stick at home. I'll be at home on Sunday
  9. bulldogjeff
    2 Mar 2010
    I may have to grab that off you
  10. Big Elf
    23 Apr 2009
    If you google the board name then the 1st hit should be the Asus link to it. Click on Support, wait a while until the page fully loads then Driver and Tools and wait again eventually you should get access to the BIOS download.
  11. Jim - ASUS
    Jim - ASUS What's a Dremel?
    9 Feb 2015
    I would advise downloading manually and updating via the BIOS, as per the previous post
  12. bulldogjeff
    2 Mar 2010
    I've tried that. Put the download in different folders and even on a usb stick. Then when it says load from location its gone. Yet when I go into the folder or on the usb its there. It's doing my head in.
    I don't need a bios update for any reason. But it's just nice to be up to date.
  13. Big Elf
    23 Apr 2009
    It's something to do with the format of the USB stick I think. Make sure it's FAT32 or possibly FAT.
  14. Jim
    Jim Ineptimodder
    2 Sep 2007
    AFAIK you needed to give it a specific filename for flashback to work - that could be the reason.
  15. Speed
    Speed I'm all you need!
    13 May 2004
    Flashback is a life saver for when you have a new CPU but not the correct BIOS version installed. That being said for regular updates, use the built in EZ Flash utility within the BIOS itself rather than anything in Windows. It is usually located in Advanced mode, then the Tools tab. Or just Tools if it doesn't have an "Advanced Mode" option. USB Sticks will be fine formatted for Fat32, put it in before posting otherwise it may not show up.
  16. bulldogjeff
    2 Mar 2010
    Lads I think you have cracked it.. I formated but in NTFS.... Can't believe I completely forgot about that. Major blonde moment going on lol
    It would explain why it's not showing up on the stick when I try to locate n in the update section.
    I'll try that later.
    Rep for that one boys.
  17. Kovoet
    26 Aug 2009
    Ah good thats you sorted then. I used the asus updater which was simple enough.
  18. Teelzebub
    27 Nov 2009
    Kov said you had taken to wearing a blond wig :eeek: seems it's true then :hehe:
  19. bulldogjeff
    2 Mar 2010
    Shhhhhhh.. That's only on club nights lol
  20. Kovoet
    26 Aug 2009
    Tel I knew you were taken but had no idea it was Jeff well I never
