Gaming BioShock Gameplay Review
Discussion in 'Article Discussion' started by Tim S, 21 Aug 2007.
  1. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I think this is correct if you develop the game for widescreen. When switching to 4:3 on a game developed in 16:9 would you expect to lose the horizontal fov or gain vertical? In my opinion you shouldn't reduce the horizontal fov on a FPS so they've added height.
  2. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Not really... the devs are effectively saying that the horizontal axis is more important/useful/preferable to the player therefore you will get the same horizontal view regardless of your hardware.
    They could have taken the view that the vertical axis was more important, in which case they would cropped it the other way.
    Ideally, both axis should be equally important if the game requires you to look up & down as much as left & right, but since we have widescreen monitors is extensive use, the devs have to jump one way or the other.
    In a driving game (generally moving and looking left & right) the width is paramount. I can't think of one offhand, but I'm sure there will be a game genre where looking up and down is more important.
    In these games where we are (almost equally but not quite) interested in both axis, they have to make a decision and cropping the height makes sense.
  3. Paradigm Shifter
    10 May 2006
    Hm...
    But the way Bioshock treats widescreen gamers then is exactly the same way that Battlefield 2 and 2142 do, then - in other words, they are penalised because they have a widescreen.
    Do you go to see a film and the cinema, and when you watch it on a 4:3 TV get extra 'on top'? No. You lose the sides. That's the way film widescreen/non-widescreen has worked, and with various companies (like nVidia) pushing 'cinematic gaming'... well.
  4. cjmUK
    cjmUK Old git.
    9 Feb 2004
    I was being vaguely controversial but certainly not sarcastic.
    Yes I have been to the cinema. And it is because we have widescreen formats at the cinema, that we have widescreen TVs and monitors. Cutting a long story short, we have widescreen cinemas because cinema owners figured they could sqeeze more people in if they made them wider - doesnt work well if you try to build them higher. And hence we have widescreen films, and consequently, widescreen TV and monitors.
    Whereas ergonomically speaking, our eyes prefer a format closer to standard 4:3 format. If you imagine each eye's view is a circle, and if we combine two eyes together we get something like a horizontal figure of eight - which is closer in shape to 4:3 than 16:9.
    So we have this widescreen fad because back in the day, cinema owners and the studios were greedy, yet out bodies prefer the conventional shape.
    And hardware manufacturers are happy to support this because they can shift more stock.
  5. Jamie
    12 Mar 2001
    Wrong, the game would have been built for widescreen and it would be absurd to reduce the horizontal fov for 4:3.
  6. naokaji
    naokaji whatever
    8 Dec 2006
    well... i think first the "format war" of 16:9 vs. 16:10 (tv widescreen vs. pc widescreen) should be resolved... because if not... they would have needed to make a 16:9 version for the xbox360 and a 16:10 version for the pc.
  7. Tim S
    Tim S OG
    8 Nov 2001
    Has anyone tested what happens in Rainbow Six: Vegas (another UE3 game)?
  8. Paradigm Shifter
    10 May 2006
    Ooh... it's been a while, but I believe that R6V also cuts the top and bottom...
    edit below:
    How much peripheral vision do you have? It should be somewhere in the region of 160-175 degrees... while your vertical field of view (without moving your eyes) will be far narrower... and that means that a wider screen would more naturally fill your field of vision...
  9. Tim S
    Tim S OG
    8 Nov 2001
    If that is the case, you would need to moan at Epic, as it would appear to be a UE3 "feature" - nothing to do with 2K Boston/Irrational Games.
  10. Paradigm Shifter
    10 May 2006
    Hang on, though. UT2003/2004 supported widescreen correctly, but there were games using that engine that did not. It's down purely to the implementation by the dev house.
  11. Tim S
    Tim S OG
    8 Nov 2001
    Well, from what I've read, GoW does the same too and that was developed by Epic Games... until that comes out on the PC, we're never going to know if this is an implementation problem on Irrational's part, or a lack of a feature on Epic's part.
    Having said that, playing the game on both PC and 360 on widescreen monitors, I can't say I've missed the pixels. Don't get me wrong here though - it's not cool that there isn't a wider FOV, but simply blaming the developer when it could infact be the engine licenser that is causing the problem isn't right IMO.
  12. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    This is terrible news. Regardless of the reasons why, a lead programmer stated this not so long ago
    Utter lies.
  13. Jamie
    12 Mar 2001
    What's the problem, I'm failing to see what all the fuss is about?
  14. DougEdey
    5 Jul 2005
    THEY R STEELIN MAH PIXELS
  15. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Yeah and me.. :eyebrow:
  16. Silver Shamrock
    19 Sep 2005
  17. K
    K 528491
    31 Oct 2001
    As Paradigm Shifter correctly states, a human's peripheral vision is far greater horizontally than it is vertical. I think my concern is that the image for the 4:3 version looks to be the norm of the kind of field of view you would get in any FPS. Thusly, the widescreen version should be a wider view. If the game's been developed with widescreen in mind, it should be using the widest natural FOV, which appears to be what it would be if that screenshot was the other way around. So what if it would cut off the sides a bit in 4:3, that's what games have been like for years. The difference is gonna be neglible if you are using 4:3.
  18. Jamie
    12 Mar 2001
    OMG ROFL, I can't believe what I am reading.
    The mistake as I can see is that the game was developed in the wrong FOV, however before anyone got hold of the PC version nobody was complaining about the FOV so why now? Just because they can see the extra height they now want the extra width too!
    I will however take back all my statements if the 360 version has more FOV.
  19. Sam0r
    24 Jun 2005
    I think its better, this way, in multiplayer someone with a wide screen setup wouldn't have any advantage over someone with a standard 4:3 monitor, and vice-versa.
    Still don't see why people are killing kittens over it though..
  20. Tim S
    Tim S OG
    8 Nov 2001
    I've just sat with the 360 version running side by side with the PC version and they're the same FOV.
    I have a widescreen monitor and a widescreen TV at home, and I can't say that I feel short changed. If anything, the game's claustrophobic nature is enhanced in widescreen (now there's a throwaway comment that'll no doubt be misquoted). That said, it's totally not cool that the lead developer said you would "see more" in widescreen.
    I feel sorry for those that have cancelled (or are contemplating cancelling) their pre-order over this molehill, because they're missing out on the best game since Deus Ex and some would argue that it's better.
Tags: Add Tags
