Bioshock Vita-Chambers: Game-Saver or Game-Breaker?
Discussion in 'Gaming' started by WarMachine, 27 Aug 2007.
  1. Game-Saver
    3 vote(s)
    30.0%
  2. Game-Breaker
    7 vote(s)
    70.0%
  1. WarMachine
    WarMachine American Swine
    20 Jul 2006
    Ok, time for another Bioshock thread... On the subject of Vita-Chambers. What are your feelings on how these were implemented in the game? Do they make things far to easy? Or do they balance out the game?
    Personally I have mixed feelings... mainly because these are all over Rapture, but they only serve the player. If these are appliances like vending machines and the like, then what explanation is there for why they don't bring splicers back (other than that would make the game rather more difficult?) or the other citizens who have died prior to your arrival? Although I can see the frustration factor going way up if they weren't there and we had to reload each time we died and try to figure out (A.) What killed me? and (B.) How do I not get myself killed this time? I can see the gameplay being extended for a great many hours due to trial and error being used at most encounters if there was a simple save/load system, which to some may be a plus.
    What are your thoughts?
  2. naokaji
    naokaji whatever
    8 Dec 2006
    i think they should be disabled on hard....
    other than that i dont really have a problem with them.
  3. Tim S
    Tim S OG
    8 Nov 2001
    AFAIK, the Vita chambers were supposed to only be used by Andrew Ryan but they were slightly flawed by design, meaning that anyone with very similar genetic code can use them (i.e. the character you play).
  4. Hells_Bliss
    Hells_Bliss New Member
    6 Apr 2007
    well they're good if you get slammed by Rosie, and you didn't have 100% health, but really, otherwise just save.
  5. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    I found that sometimes id respawn in one further on in the level and then wonder wtf where am I and how do I get back to where I was fighting the Big Daddy.
  6. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    I always reloaded when I got sent to one. I think they were a terrible idea so I played "properly" without using them ;)
  7. DougEdey
    5 Jul 2005
    What Tim said.
    Listen to the audio logs! It explains a LOT, and remember you can read them in the mission log menu
  8. Veles
    Veles DUR HUR
    18 Nov 2005
    In the PC version, with a quick save feature, I think they're pointless, but on the 360, it's not so easy to save the game, it's not so simple as a button press, on the PC, whenever I think something bad might go down, I hit quicksave. On the 360, it's a lot more effort, so it only really happens when you know something bad is about to go down. IMO they should have been more like autosave checkpoints, every time you go near one, your game autosaves, so long as it hasn't autosaved in the last 5 minutes or so. Should also make about 3 autosave slots per savegame encase you accidentally autosave when you are about to die.
    I can see why they were done, but I think there would be a much better way of doing it.
  9. NiHiLiST
    18 Aug 2001
    Fair point about the 360 version, I did use quicksave a lot.
