bit-tech 2017 refresh feedback: Bugs and errors
Discussion in 'Feedback & Suggestions' started by Dogbert666, 27 Jun 2017.
  1. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
  2. Vault-Tec
    30 Aug 2015
    bit-tech.net Forums - Error
    Security error occurred. Please press back, refresh the page, and try again.
    Every time I search...
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Odd i can't replicate it. Do you have any examples although you said it's every time you search. Also you got any network stuff going on such as TOR or a VPN?
  4. Vault-Tec
    30 Aug 2015
    I dunno, but weird stuff was happening. I tried to sign in on a new install earlier and it refused saying I needed to accept the cookies. But I never had anywhere to accept them :S
    Then for a few hours, even if I checked it, the "Stay Logged In" thing wasn't working. I'm using Chrome, btw.
  5. Vault-Tec
    30 Aug 2015
    Yup still won't stay logged in. Odd !
  6. Guest-16
    Guest-16 Guest
    There's no report post function and the spam is back.
  7. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    just reported them :)
    report is on the left at the bottom (took me a while to find)
  8. MLyons
    3 Mar 2017
    Mind PMing me details of the system and network such as ISP, browser version etc?
    I'm pretty sure all members can see the report button if not say.
  9. Vault-Tec
    30 Aug 2015
    Over mum's having roast. Will do so when I get back :)
  10. sandys
    sandys Multimodder
    26 Mar 2006
  11. MLyons
    3 Mar 2017
    Does it work in the thread you linked. If you're talking about what I think you are then all articles going forward and from maybe a few days ago should be fixed. The read more link should work perfectly and the description is just like how it was done manually on the old forums.
  12. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    No, it doesn't. All the links are generated as "http://\" by mistake. Chrome thinks "that doesn't belong there, I'll delete it" and the link works; IE and Pale Moon think "that doesn't belong there, I'll replace it with a forward slash" and the link doesn't work.
    Inspect the element and you'll see what I mean. (And while you're fixing it, https instead of http plzkthxbye.)
  13. MLyons
    3 Mar 2017
    I've just checked the read more link on this thread https://forums.bit-tech.net/index.p...dripper-retail-packaging.329185/#post-4365523. I just checked Chrome, Firefox, IE11, Edge and Safari and the link works in all of them. The inspect element isn't 100% perfect but it should be functional.
  14. Gareth Halfacree
    4 Dec 2007
    Pass, then: we've got IE users saying it don't werk, but I ain't got IE to test with m'self. (Well, I have IE3 on Windows 95, if that's any use...)
  15. MLyons
    3 Mar 2017
    I tested it on IE5 and the link works. If you can get them to send you or me the details or post here the system and software specs that would help. Wait hang on a sec are any of them using it at work by chance?
  16. MLyons
    3 Mar 2017
    I think I've fixed the link thing and it should be live soonish. I even added HTTPS just for @Gareth Halfacree
    Assassin8or likes this.
  17. Vault-Tec
    30 Aug 2015
    Still not staying logged in on Chrome. NVM, it's no biggy. But.. I have a very large and powerful phone (Oppo Find 7a) with a 5.5" screen. I have noticed there is no option for the desktop site. This makes me a saaaad panda :(
  18. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    File this under annoyance/irritation.
    For any super-long threads, the page numbers spill out of their boxes and cause odd gapping.
  19. MLyons
    3 Mar 2017
    I think this may be due to logging in from multiple locations but I'm not 100% sure and the logs aren't very useful. I'll try to see if some form of security check is being tripped.
    Got a link to the thread so i can have a mess around with it? Also what browser and OS are you using?
  20. MadGinga
    19 Mar 2009
