bit tech and chrome
Discussion in 'Feedback & Suggestions' started by captain caveman, 19 Aug 2013.
  1. captain caveman
    captain caveman life is pain
    14 May 2010
    Every system i own is struggling to access the BIT tech website if I use Chrome. The site opens up but all I see is the outer edges of the website, everything else is black .Anybody else having similar issues and any suggestions to fix the issue ?
  2. longweight
    7 May 2011
    If it is anything like this problem then try running adblock.
  3. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    I am having the same issue in FF. The main page is blank except for the outer border.
  4. longweight
    7 May 2011
    Are you running adblock?
    Adblock definitely fixes it for me, just tried the site in an incognito window and it doesn't work...
  5. Mechh69
    16 Sep 2009
    Wow adblock fixed it thanks.
  6. longweight
    7 May 2011
    No worries :)
  7. captain caveman
    14 May 2010
    cheers your a star longweight, adblock fixed it for me on Chrome
  8. captain caveman
    14 May 2010
    Still can't access bit tech on the ipad
  9. CrazyJoe
    CrazyJoe Well-Known Member
    4 Aug 2010
    Can you get adblock software on the ipad? If you can, give it a go.
  10. captain caveman
    14 May 2010
    you can get a browser with adblock preinstalled, but no adblock extension for chrome on the ipad
  11. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    Just starting doing this for me in the last hour or so.
    Banner and sides load, but nothing at all in the middle where article content usually is.
    Tested in Chrome, Firefox and IE :(
  12. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    And magically fixed again, it seems.
  13. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    it is to do with the adverts not being properly coded
  14. Nexxo
    Nexxo Stopped treating this country as if it was my own.
    23 Oct 2001
