Bit-Tech Best Buy
Discussion in 'Hardware' started by *mat-ster*, 31 Dec 2005.
  1. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    I think it's about time Hardware and Overclocking had a sticky for best buy / performance for PC components...
    I Know it would be changed almost weekly but it would help alot of peeps who need impartial advice etc...
    --------------------------VALUE--------------------------BEST BUY-----------------------PERFORMANCE
    CPU =-------------Athlon 64 3200+ (939)--------Athlon 64 X2 4200+ (939)-------Athlon 64 X2 4400+ (939)
    Alternative------------Opteron 144 (939)--------------------------------------------------------FX60 or 4800+
    CPU Cooler =---------------Stock----------------------Tt Big Typhoon
    SLI MoBo =-----------Abit AN8-SLI-----------------------Asus A8N-SLI Premium---------Asus A8N32-SLI Deluxe*
    Alternative----------------------------------------------------------------------------------------DFI SLI-DR
    X-Fire Mobo=--------------------------------------------Asus A8R-MVP-----------DFI LanParty UT RDX200CF-DR
    VALUE RAM =---GeIL 1GB (2x512MB) PC3200 Value Dual CAS2.5
    -------------------Crucial 1GB (2x512MB) PC3200 CL=3
    BEST BUY RAM =---------------------------------Corsair DDR500/PC4000, 3-4-4-8
    PSU =--------------Antec TruePower 380W----------Tagan 580W Easycon--------------Enermax Liberty 620W
    Alternative----------------------------OCZ ModStream 520W or Hyper Type R 580W----------Seasonic S12 600W
    Harddrive = --------------------------------------------------------------------------------WD Raptor 74GB or 150GB
    ----------------------------------------------------------Hitachi 7K400--------------------------+ 500GB Hitachi 7k500
    ------------------------------------------------------------------------------------------------Seagate 7200.9
    Nvidia Graphics Card =---------------------------7800 GT 256MB PCI (XFX, BFG)------XFX 7800GTX Extreme Gamer
    ATI Graphics Card =----Sapphire X800 GTO2------------------------------------------------X1900XTX
    Monitor = ---------------------------------------------Samsung 940b 19"---------------------Dell 2405FPW
    Keyboard = -----------------------------------------------Logitech G15
    Mouse = -----------------------------------------------Logitech MX518-----------------------Logitech G7
    Alternative-----------------------------------------------Razer Copperhead
    Headphones = ------------------------------------Speedlink Medusa 5.1------------Plantronics Gamecon Pro 1
    Sound Card = ----Creative SB Audigy SE 7.1----------SB X-Fi Xtreme Music------------------SB X-Fi FPS
    Alternative =
    DVD Writer =----------------------------------------NEC ND 4551 (all groups)
    Case =--------------------------------------------------Akasa Eclipse 62---------------------Lian Li V2000*
    Surge/UPS=-----------------------------------------------Oneclick P7NFOC
    Speakers =---------------------------------------Logitech's THX Z-5300e 5.1
    Well then "Price, performance, availability balance".....what do you think they should be?
    Yes I know unanimous agreement is impossible but a general consensus is better than nothing. :thumb:
    * Do not combine - compatibility issue with heatpipe and upside down case design.
    Useful build guides and websites
    The Hitmans gaming PC Bit-tech build guide
    Sharky High End and Budget PC kit list
    Hard OCP System Guide
    Guru of 3D Buyers Guide
    Firing Squad's Hardware Upgrades 2005 and Super PC
    PC World Best of 2005 100
    Build Your own PC website
    http://sysbuild.corsairmemory.com/report.aspx?id=2&sid=1
    http://arstechnica.com/guides/buyer.ars
  2. Mister_Tad
    27 Dec 2002
    I think a few columns would make more sense, a pick for each budget category ie 1GB value ram, 1GB performance ram, 2GB performance ram depending on budget
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    I intend to write a guide on selecting components for your PC very soon which covers budget, mid-end and high end stuff. Should be done in a few days :)
  4. phuzz
    phuzz This is a title
    28 May 2004
    Consensus at the momet seems to be that 300Gb is about the best size/price of hard drive at the moment, just for the record like.
  5. *mat-ster*
    10 Mar 2002
    Great Hitman, :clap:
    Looks Fantastic so far, included link.
    Any Mods readin this is this OK, can you help?
    I just think it would be a great resource...for example I'mm lookin for a headset but do not know where to start. Yes I know there are plenty of online reviews but hey how many are impartial and rec'd by real world peeps :)
    Cheers All,
    Matt
  6. Mister_Tad
    27 Dec 2002
    Something along these lines would be a good sticky once its up and running. I'll keep an eye on it and sitckify it if it is stick-worthy :thumb:
    Ill have a bit of input here:
    hard drives:
    budget: anything current gen, around 160GB+, whatever is cheapest
    best buy: 250-300GB Hitachi 7k500 or samsung P120, in that order
    performance: WD 74GB raptor (or the new one when its out) + best buy drive
    PSU:
    budget: antec 350w, which comes with the case id suggest
    best buy: Tagan, Hiper, Antec, Enermax, around 450w/£65
    Performance: PCPnC, OCZ or a high end Zippy or Seasonic
    CPU:
    Budget: A64 3000+
    besy buy: A64 X2 3800+
    Performance: A54 X2 4400+ (theres always the 4800, but its unlikely to clock much better, if at all, so a waste of money over the 4400 imo - until the FX60 pops up next week)
    RAM:
    Budget: corsair or OCZ value PC3200 2x512MB
    Best Buy: too many choices here, 2x512 PC4000+ kit is ideal, Crucial Ballistix, OCZ or Corsair performance series
    Performance: 2x1GB of PC4000 - Crucial Ballistix, OCZ 4000EB, Mushkin Redline XP4000
    CPU cooler:
    Budget: if not stock, then a Thermaltake Big Typhoon
    Best Buy: Thermaltake Big Typhoon
    Performance: water, but thats a whole other thread in itself
    DVD Writer:
    Budget: NEC 3550/4550
    best buy: NEC 3550/4550
    Performance: you guessed it, NEC 3330/4550
    Sound:
    Budget: onboard
    best buy: onboard? dunno tbh
    Performance: X-fi FPS (or an EMU 1820 if youre more serious about music than gaming)
    you forgot GPU off the list btw, thats a funny one any way
    for a gaming rig, is something like an x800XL/6800GT budget now? or is that the 6600GT area?
    with best buy, is that 7800GT area or x800/6800
    and performance, while a couple of 7800GT/X in SLI is obviously the best performance, imo a single card, either a 7800GT/X or a x1800XT, makes more sense
  7. *mat-ster*
    10 Mar 2002
    Yep Mr T,
    Harddrive - Wow, when is the new Raptor out?
    PSU - OK an Antec for Value (with Case) perhaps a modular PSU for Best Buy The Tagan easycon 580 seems to be the best around at the moment. Zippy PCPnC hard to get hold of in UK, the new Seasonic's are luverly :)
    CPU - FX-57 dare I say it.....
    Big Typhoon - The Zalman Flower (120mm) is good alrounder if a bit big.
    RAM - This is gunna be hard changes daily :eeek: plus prices.
    DVD - The plextor and Pioneer DVR-110D are good but guess what I have :)
    Sound - Best Buy = Onboard, now thats just silly Tad, you can pick up amazing deals at the moment. Perhaps not the latest stuff. I know peeps hate Creative does anyone else have any alternatives M-Audio Delta 66, or Terratec Aureon 7.1.
    Added Graphics card....
    Anyone else have some ideas - Thnx in advance Matty
  8. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Hitmans version of this, is similar.
    (Budget/best buy/performance)
    But its much much better/longer. ;)
  9. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I've done that too last week, I haven't uploaded it to my site yet. Quite easy to do, but the problem being you have to update it every couple of months :/
    For GPU, the performance one would be two 512MB 7800GTX in SLi, no doubt (for now).
  10. Mister_Tad
    27 Dec 2002
    the server edition is as good as out, the gamer edition shouldnt be too far behind
    I have both the 110D and the 4550, i definitely prefer the 4550 over the pioneer, it feels better built (ie the tray mechanism), its quieter and afaik its better with more 16x media than the pioneer
    yeah youre right, i just checked on the cheapest x-fi and it was £100, didnt really notice that there are good cards for loads less :blush:
    not imo, while it is obviously the fastest there is I dont think it belongs in the performance category. Id consider "performance" a category that would be for high, but not limitless budgets. To me it doesnt make sense to spend over £1000 on graphics (if you can even get hold of them) when a pair of 7800GTs for half the price doesnt really lag far behind in the real world. I reckon a single 7800GT/X would be more suited, 2x7800GT at most.
    to me 2xGTX512s belong in a no expense spared category with dual 280s, a SCSI/SAS disk subsystem and 4GB+ of ram
    maybe rather than ambiguous labelled categories, a specific budget should be set out like £500/800/1200?
  11. *mat-ster*
    10 Mar 2002
    You bet, Hitmans thread is brill and should be stikified NOW this is intended to be a summary of key components not a detailed guide!
    Hence the Linky.........
    You have a good point regarding the price bracket and availability Tad, unfortunately a moving target :worried:
    Matt :)
  12. Fiver
    Fiver What's a Dremel?
    24 Aug 2002
  13. Pookeyhead
    30 Jan 2004
    Why is the X2 4400+ the performance CPU choice? You have a budget, and value option, so surely the fastest CPU should be in there? WHy not the 4800+ or the FX57? Just cos the 4400 clocks as high (maybe) is not the point.. not everyone overclocks, and it's currently the fastest dual core AMD chip.
  14. mrbungle
    20 Sep 2004
    Best value isnt a 3000+ any more
    939 Opterons have seen to that
  15. Neoki
    Neoki Minimodder
    26 Oct 2004
    The best motherboard is the DFI SLI-DR Expert
  16. Lucy2005
    Lucy2005 What's a Dremel?
    25 Jun 2004
    i think that this is a great idea and i'd love it in a table, not as Mister_tad done (sorry hun)
  17. Mister_Tad
    27 Dec 2002
    the same reason the I dont think 2xGTX512 should be in for graphics. At the end of the day this is supposed to help people and a 4400 is a lot more accessible to people than a 4800, and 9% more performance for 50% more cost? for 2 cpus that are likely to clock exactly the same? I for one don't see the point (I mean, come on dude, my 165 eats your FX57 for brekkie xD). Everyone has a budget (tbh even with unlimited funds I still wouldnt get the bar-none fastest CPU or graphics) and nobody wants to spend more than they need to. And I reckon its pretty safe to assume that the vast majority of people reading suych a guide would be interested in overclocking the system. Just my 2p i guess.
    ok so you lost me there
  18. MrWillyWonka
    25 Jul 2004
    I disagree, the rightmost column is headed "performance" and if you want performance, you get the best, I agree with Pookeyhead, the best processor and best graphics cards should be under the performance category.
  19. *mat-ster*
    10 Mar 2002
    I have to agree with Mr T on this one Pookey (You do have a valid point) but we should weigh up the balance between availability, cost and performance for all categories.
    Lucy I think you are refering to "Hitmans" Gaming Rig guide....
    Bungle - WoW Check out http://www.komplett.co.uk/k/kl.asp?bn=10483
    I have added the 144 to the budget certainly worth considering.
    Yes the DFI board is very OC friendly but can be a bit "fussy"....
    Willy if we go for Pure performance then we end up here which is pointless really. I will list as alternative no doubt they will drop in price soon anyway.
    Thanks All,
    Matt
  20. Mister_Tad
    27 Dec 2002
    the best? well then thats dual 280s (pity theres not a 4-way SLI board :hehe:), a 15k SAS array, a nice solid state drive to go along with it, why not 8GB of ram and throw in a couple GTX512s and a PCPnC 1kw. Add to that 2x Dell 3007s and you have yourself the "best" gaming system. Hell why we're at it why not chuck a 10gb ethernet in one of the pci-x slots.
    does anyone see my point yet? :hehe:
