SketchUp Bit-Tech Case Design Contest - SFF Edition - Powered by LOSIAS
Discussion in 'Modding' started by confusis, 4 Dec 2011.
  1. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Yup, but I was more thinking about a well known SFF case. Standard are good, but should not be always used.
  2. Cheapskate
    13 May 2007
    @Guille - Thanks.:D
    @jrs77 - The core I'm working around is the motherboard area and a 2x120 radiator. So in reality it's around 12" x12" x7".
    @Ian - Coke Can sounds good. Here's one.
    -While were at it: This is an idea I had for doing away with the barbs. I figured with a little CNC code editing and a special bit, I could mill inverted barbs directly into the blocks.
    ...I'm just waiting on my nuts to get a bit more brass content...:worried:
    What do you think? would it work?
    Edit:
    -You are right. It's still kinda big.
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    Nice idea for the barbs, but as I've had three blocks leaking and destroying the systems allready I'm not too confident with anything else then good old pressure-fittings... or even better, sealed and completely soldered systems. All three blocks failed because of the O-rings, leaking water between the copper and the acrylics top.
    That's why I'd say, that it's too much pressure to go with those integrated barbs.
  4. GuilleAcoustic
    26 Nov 2010
    Nice one Cheaps and thanks for the kind words JRS. Here is the coke can size comparison :
  5. Cheapskate
    13 May 2007
    :lol: How do we know that's a real Coke can.:D
    -If we are building small, then this one should really put you off. The front is the same radiator enclosed in a shroud. the top bulkhead is converted into a reservoir.
    -The Confusis color schemed board made this one look like a sandcrawler. The frame is made of 1/4" bars. The panels are 1/2" plastic.
    -I guess I'll be discarding this and starting with a new layout. -80mm x 5 radiator?
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Well... OK...
    I can't actually criticize something without giving it a shot... can I? ;)
    So here it is. The base consists of only two cut and folded sheets of aluminum, resulting in something as small as 15.8 liters with room for a full rig of hardware.
    No ideas about a shell so far however.
  7. Cheapskate
    13 May 2007
    New core:
    80mm x 3 radiator. Pump is mounted directly to the CPU block. I had to remove the memory heatsinks to get everything inside.
    I'll probably go rogue soon and do whatever I want. Tidy box packing isn't my bag.
  8. aeidau
    aeidau Industrial Designer
    13 Mar 2010
    Hmmm I might give this a go. Does anyone know of a good free .skp to .sldprt converter? Or can someone upload a .iges file?
  9. jamsand
    jamsand Minimodder
    21 May 2011
    Phantom power mod would be awesome for something like this?
  10. GuilleAcoustic
    26 Nov 2010
    I have integrated a naked wallwart and a pico PSU inside the base to provide all the required juice :D
    EDIT : with the Coke can provided by Cheaps matey :thumb:
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    Passive, benchtable-style HTPC.
    Need to model a Hauppauge WinTV HVR-5500 and finish some details, before I can start rendering the whole thing, but all in all that'll be from my side :worried:
  12. GuilleAcoustic
    26 Nov 2010
    Very nice one there JRS .... slim and compact :thumb:. I'm thinking about something similar but in a ITX FF for my everday work.
    Cannot wait to see the renders :D
  13. Xye
    Xye What's a Dremel?
    21 Nov 2010
    I've had this trouble too.
    You can get SKP to STL file converters but then you have to use a different package to convert the STL into a solid model ( I have done this before)
  14. aeidau
    13 Mar 2010
    I've found a workaround su2stl plugin for SU - export in millimeters and then open in SW and it can parse the STL file and then you can fix any surfacing problems with the surface tools if needed.
    But its still all a pain.
  15. Xye
    21 Nov 2010
    Really?
    I've found when I try to import stl's into SW they are a dumb surface which cannot be interacted with.
  16. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    Still not good at using SU... ah well
    Here is my take at doing the SFF build. Still a total noob at this, taking forever :wallbash:
    Dimensions would be around 10X25X50 (WXDXH cm) and the mobo would be upright.
    Things to do...
    get the case done, 5mm orange acrylic and 1mm black aluminium and add a window
  17. j0rd
    j0rd FLOSS folder
    13 May 2011
    @the_kille4; i like it, kinda reminds me of a rack mount server chassis
  18. aeidau
    13 Mar 2010
    Yeah your right... :sigh:
    Yeah I agree, looks good.
  19. Cheapskate
    13 May 2007
    Like some of the stuff I'm seeing here. It's turning into a limbo competition.
    -Yesterday's rig.
    There's room for 5 ssd drives at least, so it's still too big for this crowd...
    -New layout. That number at the bottom is with the hidden coverplates.:D -A bit under 54mm since I'm the only 'murican. I should switch my measurements around for you guys.
  20. GuilleAcoustic
    26 Nov 2010
    Nice ones Cheaps ... dun worry about the inches, a simple x2.54 gives us the metric mesurements ... still manageable without a calculator :D.
    I've worked on the cpu cooling. Custom heatsink using the same slipstream fan from the new Scythe Big Shuriken (120mm). I'm going to use 2 slipstream like on the Scythe Musashi but mounted under the rad, like on the Scythe Kozuti.
    The two fans suck the air from the case and blow it outside, throught the rad fins. It's a pretty close fit, but it fits inside the case :D :
