Scratch Build – In Progress Bit-tech community build - Bobs suprise rig! *COMPLETE*
Discussion in 'Project Logs' started by Otis1337, 9 Jun 2015.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    posted on the market place thread about a monitor.
    Basically could do with one. Nexxo is bringing one when he gets free time, but nothing till then.
  2. Otis1337
    28 Nov 2007
    We have a problem. Power supply arrived, plugged everything in. and something is dead.
    Booted with power, all fans spinning, CD drive active but monitor would no wake up. (flashing power led but did not say no signal)
    Computer then rebooted it self, still no change to monitor.
    Swopped out the graphics card for one of my old 8800's, Still no change.
    Put original card back in, plugged power cable back in and my house electric alarm went off. (not good)
    Computer will now not power up at all. tired 2 different kettle leads.
    Im afraid the power supply my of just killed the motherboard.... or the motherboard was DOA.
    I have no idea how to confirm this or what to do now.....
    Please help....
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Basic stuff to try.
    Check all cables.
    Check everything is seated correctly particularly the RAM, CPU heatsink,
    Remove everything like GPU (does the mobo have onboard? ) optical drive, bar one stick of RAM .
  4. Otis1337
    28 Nov 2007
    Ok taking the GPU out and having nothing in the PCI-e has given me power.
    there is no onboard graphics.
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Are you saying that the on board GPU is not working?
  6. Otis1337
    28 Nov 2007
    there is none, on board with this motherboard comes from the CPU. G3220 does not have one.
    Just tried putting GPU back in, and now powering up with graphics card in. Still nothing on the monitor
    WTF is going on...
  7. Fingers66
    30 Apr 2010
    The Pentium G3220 comes with on board Intel HD graphics.
    Sometimes a BIOS can get confused about which display to use, I have seen motherboards get confused when detecting if a discrete card is plugged in.
    Remove the 5770, reset the BIOS via the CMOS jumper (next to the battery) then plug in your monitor cable to the back of the motherboard and restart. Don't have anything else plugged into the m/b (HD or DVD etc).
  8. Dr. Awesome
    Dr. Awesome I go to 11
    12 Jan 2010
    Could it be the particular PCI socket the GPU is mounted in?
  9. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Is the pump on the H50 working? or is a fan attached to the CPU_FAN header? Could be if no RPM signal then the mobo kills the POST. Hows about the RAM? could you swap out a stick of your own to test?
    J.
  10. Otis1337
    28 Nov 2007
    pump is in PWR_FAN, rad fan is in CPU_FAN1
    I can hear the pump working.
    going to try fingers idea now. brb
  11. Otis1337
    28 Nov 2007
    It was trying to boot from on board!
  12. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    lol.. glad it working.
    J.
  13. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
  14. Otis1337
    28 Nov 2007
    your dvd drive just came Madginga, thanks!
    , so as i only have one working monitor ill be off for a bit getting win7 on and stuff.
    See you all tonight with final photos of it all working.
  15. MadGinga
    19 Mar 2009
    Cool! Have fun :D
  16. Fingers66
    30 Apr 2010
    If you can't see a display when booting with the 5770 installed, remove the 5770 and see what the settings are under "Chipset" and "System Agent Configuration" in the BIOS.
  17. Otis1337
    28 Nov 2007
    All done, waiting for it to get a bit darker to do final photos.
    Thanks everyone!
  18. Otis1337
    28 Nov 2007
    All packed up ready to CARRY it to bobs house tomorrow! ;)
  19. bulldogjeff
    2 Mar 2010
    Thats not a bad looking case. Good to see it all together.
    I'd like to see the look on his face when he gets it..
    Pics?
  20. Otis1337
    28 Nov 2007
    If he's not to camera shy I'll take one with him with it.
