SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looks very nice :)
    what software are you useing ?
  2. Steveo
    Steveo What's a Dremel?
    6 May 2009
    Wow those look amazing. I'ma getting Solidworks and maxwell reneder soon, hopefully I can produce the same results. :D
  3. emir_
    emir_ What's a Dremel?
    3 Aug 2007
    Thank you. I'm using Maxwell or Photoworks.
    Got bored today, made a new block.
  4. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Wow guys. Stunning work.
    Really need to get my rear end in gear and start rendering all the stuff I make.
    Need to get to grips with Kerkythea. All other stuff made in Rhino 3d 4.0.
    So expect some renders some time.
  5. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    I can't get Bevel Mapping to work in Kerkythea. It doesn't matter setting i put it on, it never does anything. Even if i stick it up to 7.00, it doesn't do anything in the slightest. I followed the tutorial on the website, but it doesn't do it. Anyone got any ideas?
  6. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    Bevel mapping in KT is more like a specular map on just the corners edge to make the edge appear more rounded (light reflecting off the corner at the angle you set it), it will not physically change the model to make this happen, modelled corners/bevels are always more effective and more accurate.
    If your camera is at the wrong angle to the edge where you set it in accordance to the lights you may not even see this effect, as it rely's on the right reflective angle for the specular to be visible...
  7. cronicash
    25 Aug 2009
    Gave the res a go alike some others i see going on, just a quick 30 min render...
  8. Metric
    Metric has a bazooka
    1 Jun 2009
    Cronicash: Nice job, but wouldn't the reservoir still leak since the bolts are inside the groove the oring sits in? It seems the water would leak from the bolts first before being stopped by the oring...:confused:
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    your best render yet metric!
  10. oliverw92
    15 May 2009
    Metric that is stunning!
  11. cronicash
    25 Aug 2009
    Yeah probably... I only spent half an hour on modeling and texturing anyways. Cheers and likewise....
  12. Burnout21
    9 Sep 2005
    only started this CAD model yesterday afternoon, but it was a dirty mock up for a conceptual front panel I am considering for my project log (link in sig).
    EDIT UPDATE
    another render.
    Solidworks 2010 and photoworks 360 2010
  13. Combatus
    16 Feb 2009
    Is this the one I've seen on XS in months gone by? Luuurrrrvly
  14. confusis
    confusis Kiwi-modder
    5 Jan 2006
    i still say build it
  15. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    I thought ill just leave this here...
  16. lenne0815
    4 Jul 2009
    hum, render threat seems a bit slow lately, so something totally unrelated here....
  17. stonedsurd
    11 Mar 2009
    I love this thread.
    I'm thinking of taking CAD/CAM classes in Univ. (Yes, I know it's a wonder a bit-techer at univ hasn't already done the needful, but I'm slow :p)
    Lenne, I thought I'd commented on that render you posted but I guess I didn't :blush: Looks great. How long did it take? And was it done with KT?
    Also, the furniture designs are STUNNING! My mum's totally fallen for the armoire and sideboard.
  18. lenne0815
    4 Jul 2009
    Thx, i actually build the sideboard
    http://lenne0815.deviantart.com/art/My-apprentice-piece-157371166
    all renders are 3dsmax / maxwell render.
  19. stonedsurd
    11 Mar 2009
    Wow. How hard was it? Do you have in-progress pictures?
  20. lenne0815
    4 Jul 2009
    It was 120 hrs hard and as it seems i lost build pics of it, i took some but dunno where they are now :(
