SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Gun looks great Robo! KeyShot render looks sweet too. Seems there's lots of new toys coming out. Modo 501! Vray 2.0 (for 3DS Max), nice x-mas list :)
  2. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    Vray 2 RT GPU dosent run on my 4870x2, ich checked opencl with benches and it works just fine, vray crashes with the message "failed to compile ocl kernel" any suggestions ? ( on fermi it runs fine as far as i could find out )
  3. LooseNeutral
    13 May 2010
    Have you got the latest "Hot fix" patch for Max? I believe it's up to no.3 -
  4. lenne0815
    4 Jul 2009
    No, the vray render server fails, has nothing to do with max.
  5. LooseNeutral
    13 May 2010
    Hot Fix deal is for Maya... my bad:( Any way, I've got it running on Max 2011 Win7 32bit. No crashes just slow. Running Win on imac using parallels. So fixes for bugs being reported at other sites. Check your PM :D
  6. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    what do you think of my motherboard ? :)
  7. LooseNeutral
    13 May 2010
    I've been wondering what you've been up to! :D Looks great man.... have you been playing with the Ray 2.0? I've been play'n around with 3DS Max a bit but ..... LOST IN SPACE, LOL . Have you shown this to craigbru? he he he
  8. Dark~3nergy
    14 Jan 2007
    haven't had much time to play around with vray 2.0,
    i tried vray RT for gpu though, works decently with my 5870, it isn't very powerfull though.
    i want a tesla now :D
  9. lenne0815
    4 Jul 2009
    Cute thing, bit hard on the dof there though ;) i cant get rt gpu to run on my 4xxx series card :(
    but theres Maxwell Fire! aswell :D
  10. Dark~3nergy
    14 Jan 2007
    hehe, thx.:eek:
    i don't think you can use vray rt with 4xxx cards, since they are based on the R700 ship which doesn't support OpenCL
  11. emir_
    emir_ What's a Dremel?
    3 Aug 2007
    Thanks LooseNeutral & Roboduck! Photoview is easy to use, very fast and pretty good. But not good as others. So I'm using Maxwell again. I've used it before but not an expert, not a good user either :D Here's a work without adding custom materials;
    I wanted to add some specific material to the ground, tried some wood options from MXM Gallery. But the result is unexpectedly ugly. Surface looks like some Win98 render, in a very bad quality.
    And advice on that? I wanted something like Metric's;
    http://forums.bit-tech.net/showpost.php?p=2237634&postcount=588
  12. lenne0815
    4 Jul 2009
    I think its jsut the scaling of the texture, u scaled it way to large...
    It does support ocl but unfortunately not the extended feature set vray uses... :( which is E-BIF, FFT and BLAS3
    Its quiet unfortunate actually because my 4870x2 is really fast enough for every game out there and even the newest single gpus beat it by just a small margin :(
  13. emir_
    3 Aug 2007
    I thought it's the scaling too, but couldn't find how to fix it :sigh:
  14. LooseNeutral
    13 May 2010
    I looked at Max 2.5 and told myself not to go there yet....Stay....Away....From....the Light :eeek::lol: ! I've got enough on my hands with AR3 for now and just started play'n with VRay. Really want something better than Sketchup atm. Looking at ViaCad or Solidworks. Hope the learning curve isn't too overly steep.
  15. lenne0815
    4 Jul 2009
    First i would have to know what Program u use... For max the modifier is called uvw map, u can adjust textures there, in other programs is called differently but it works quiet similar.
    Just a quick tp: google "texture size tut *programm name*" and ull find it by urself.
  16. emir_
    3 Aug 2007
  17. lenne0815
    4 Jul 2009
    For maxwell u can adjust it in maxwell studio, but i mean the MAIN program, the one u drew in, usually u manipulate the textures there...
  18. emir_
    3 Aug 2007
    I'm using studio as well, tried the tips there.
  19. VNZL
    VNZL What's a Dremel?
    29 Nov 2010
    Question about exporting from SU to autocad 2011..
    I have been having some troubles with some models I have found on 3d warehouse and I would really like to use them as reference (such as mobos, rads, pumps, fans), that i really don't want to spend hours modeling so I have been exporting the them form SU to DWG. to use in Autocad 2011 but the things is the file are EXTREMELY harsh on my PC, I mean HORRIBLE panning and zooming in realistic or any other (non-wireframe view)...
    The thing is I am so frustrated because of it since I have done autocad file of similar or more complexity than those files and the PC does not behave in that way...
    I have been exporting only the faces (in SU export options) but still the files are horrible to work with...
    To give you an idea of whit I am working whit:
    950 i7 OC to 4.2ghz on H2O
    12GB 1800mhz DDR3 gskills
    GTX 570 stock
    sabertooth mobo
    single 1tb HD
    I have actually made copy of a rad on autocad with native tools from the programs and it works smoothly... I am fried I can't seriously arrive to a solution by my self, please i would really like to know if theres a way I cant export SketchUP files in a way that can be use in autocad 2011 please...
    3Dwarehpuse is such a great tool that I really want to take advantage of since it can save me soo much time modeling things that someone already did and are willing to share....
  20. jhanlon303
    7 Sep 2006
    your renders are better than my photos of real stuffz. Maybe I should retire. Excellent
    john
