SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    wow darky, just wow...
  2. ixmatal
    ixmatal What's a Dremel?
    16 Nov 2010
    Help with lighting in Vray
    Hello,
    I have only been playing around with Vray for the past 2-3 weeks and I am having serious trouble figuring out the lighting.
    Here are 2 example pics ( also my case design entry ) this is using 2 rectangular light or 4sq meters each set to 90 power that are approx 2 meters from the subject, and 2 8sq meter set at 45 power approx 4 meters from the subject. How do I get better illumination?>
  3. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    Here is my first render of my iphone. Took around an hour to model it. I need as much help as I can get on making the render look better, just worked out how to adjust the materials a bit.
    Using Photoshop360
  4. stuartwood89
    20 Aug 2008
    That's a pretty good render. I would put a screen image on there, cause it looks a bit blank. Maybe you could move the frame up a bit for a higher angle to show some more detail.
  5. Tangster
    23 May 2009
    Just playing with render settings.
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Haha.
    I like it when people post a perfect render that could be mistaken for an actual photo and calling it "playing around" :hehe:
  7. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looks very nice Tangster!
    this also applies for the 2 people above :thumb:
  8. Tangster
    23 May 2009
    I just saw your open plan room, great design and the render is stunning as well.:thumb:
    @ixmatal, Vray has very good HDRI and GI options, try setting a sphere with a HDRI map to provide a general all round illumination map and use spot lights to light specific areas of the design better. Personally I think you've lit your case very well.
  9. Dark~3nergy
    14 Jan 2007
    thanks tangster ! :)
    made this this morning :)
  10. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Great renders guys :D
    @ Dark - If that was landscape i would be begging you for a wallpaper version right now :D
  11. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Oh my :jawdrop::rock: Great stuff going on. I'm love'n that nasty room there Dark :hip: Might I ask what textures you're using on the walls and rusty conduit ? Did you surface paint any of it :confused::thumb:
  12. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    :jawdrop: Oh my god it so pretty! You have a gift my friend :thumb:
  13. Dark~3nergy
    14 Jan 2007
  14. ixmatal
    16 Nov 2010
    tangster - thank you, I made a spotlight and it was night and day difference, I couldn't figure out why, so I deleted all of my lighting and re-created it and now there is no problem (!?)
    I really don't like trying to work sketchup/vray, too many bugs, for instance if you look close at the first pic you will notice that all the components on the motherboard are grayed out.
    Anyway working on another couple of renders, I will post them later
    Thank you!
  15. Tangster
    23 May 2009
    Vray does that sometimes, I think it because it's searching for the textures in the wrong folder. You have to manually direct it to the correct paths.
  16. LooseNeutral
    13 May 2010
  17. Editor22
    3 Jan 2009
    Cheers <3
  18. Guest-23315
    Guest-23315 Guest
    Just basic renders in Cobalt of my latest design project.. 28m long walkway.
    Taken SUCH a long time to design as the with the entire building structure being 56m long, my laptop chokes badly.
  19. LooseNeutral
    13 May 2010
    Well, I've been playing with some max lately. going through a mega load of tuts. using that nice creepy scene, you posted there Dark, as a desktop now. took it from " http://mind-rust.deviantart.com/gallery/#/d395jej " . I'm wait'n for the mad axe man to come up those steps :D
  20. Dark~3nergy
    14 Jan 2007
    Glad you like it :)
