SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. danitgeek
    danitgeek Designer
    17 Sep 2010
    Does anyone know where i can get dark mesh metal for kerkythea
  2. FDAD
    FDAD What's a Dremel?
    7 Mar 2011
    This looks so real :eeek:
    Amazing job! :rock:
  3. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    @Razer.... you and that damn worm. lol . Hurry up and get your rig running, I want more hehe
  4. danitgeek
    danitgeek Designer
    17 Sep 2010
    Quick Render need more editing.
    Whats the best place to get materials for cinema 4d ?
    Cinema 4D R12
    Google Sketchup
  5. Tangster
    23 May 2009
    Most of the official Cinema4D material repositories are very out-dated(and so look like trash), I create all mine from scratch. I know I have some material packs on renderosity and deviantart(free) so you may wish to look there.
  6. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    not to knock on your render
    your circle for the fan needs more surfaces then 24
    you have a nice arc at the PCIe x16 slot that looks smooth
    yet you can clearly define the edges in the circle on the fan hole
    if its just a plane and not a solid (i.e. 3 dimensions to it) then just fill it back in and select your circle tool
    type in a higher number (50 or 100) before you start drawing
    then re draw the hole and voila!
    it will be smooth
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    than
  8. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
  9. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    ... :D
    pls be precise guys !
  10. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    made this today :D [​IMG]
  11. ixmatal
    ixmatal What's a Dremel?
    16 Nov 2010
    Dark - holy ^#$^!!!! - that is very well done!
    I think I have asked before, but what setup are you using? And how many hours in layout was this one, and how long / how many passes was this render? Is this part of the house you were working on? ( You were the person designing a new home correct? )
  12. Dark~3nergy
    14 Jan 2007
    I'm using 3ds max 2010 and vray 2.0, modeling and texturing took about 4-6h although it's not finished, and rendering took about 20mins. It's not part of that house i've posted earlier, it's just some small 8x7m house.
  13. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    A little something I'm working on.
    Dark~3nergy likes this.
  14. cronicash
    25 Aug 2009
    Had to make some recycle bins.. (rotational plastic...)
    Buggered up on the normals with the whale....
  15. Dark~3nergy
    14 Jan 2007
    That looks very nice sleepstreamer, what software are you using ?
  16. Sleepstreamer
    23 Jul 2006
    Thanks dark! I'm using Maya 2011 and MR for this one, but I'm currently learning Max aswell (mostly for the Cebas plugins as Houdini is seriously difficult to get into).
    Eagerly awaiting the 2012 versions of them both :)
  17. cronicash
    25 Aug 2009
    Started making a watch this morning (couple of hours modeling) ...
    Not finished yet...
    Doubt i got the gamma right... :p
  18. cronicash
    25 Aug 2009
    Made some adjustments...
    confusis likes this.
  19. Tangster
    23 May 2009
    Looks great conic. Is it your own design or based on an existing movement?
  20. cronicash
    25 Aug 2009
    based on existing, a few differences...
