SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    U should definetely OC ur q6600 to atleast 3,2 Ghz, the performance increase is huge especially if u do it via 8x multiplier and high fsb speeds ( got my main q6600 @ 3,5 and my render node @ 3,3 )
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Tried it but my XFX geforce9300 mobo doesn't keep up with even 2.8GHz :wallbash:. Tried everthing, foolowed every single Q6600 OC thread ... but this mobo is not good at OC. Win 7 freezes, CPU stablility test cannot even pass the 1st test :'(
  3. lenne0815
    4 Jul 2009
    Oh man, what a letdown, @ 2,4 ghz the quad is not exactly fast it should choke ur gfx quiet a bit too...
  4. GuilleAcoustic
    26 Nov 2010
    Now I'm hating you (j/k) :hehe: :lol: ... yup it does, especially since I'm still using a 17" LCD :wallbash:.
    Upgrade time is coming :rock:
    on my Gigabyte EP35-DS4 it was runing @ 3.4Ghz without any problem ... but the mobo blew up, taking the dvd burner 2 HDD and my 9600GT with it (out of waranty of course). Had only the CPU, PSU and RAM left ... with low budget I bought a cheapo mobo with an "decent" IGP
  5. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    you should get a new screen if you're still using a 17" display :D
  6. GuilleAcoustic
    26 Nov 2010
    Why are you so mean at me :waah: .... it's planned :D, just not sure about which one. It will just be IPS or PVA (hesitating between a NEC or an Eizo, but it is probably overkill). Dell IPS are too expensive here (500€ for a 24") while you can get a NEC or Eizo 23" IPS for 380€.
  7. lenne0815
    4 Jul 2009
  8. GuilleAcoustic
    26 Nov 2010
  9. lenne0815
    4 Jul 2009
    German site was just random link, but i mean ips panel with display port input for 200€ i think im gonna buy 3 of them soon :)
    and why would u do 7 years of german without being physically forced to ? :D
  10. GuilleAcoustic
    26 Nov 2010
    I took it as first language ... but I think that I was just another dumb teenage and didn't made that much effort at foreign langages :wallbash:. I'd really like to "re"learn it now, just have to find some time (maybe during transport time and during lunch break)
    Edit : sneak preview of the layout and the size .... have to draw the outside but I already have everything in my head :). Dual Xeon E5620 (2.40GHz - 4 cores - 8 thread) + Asus Z8PH-D12/IFB + Asus EAH5870-V2 :
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    That's a nice first idea. The size of the board makes interesting case-setups possible.
    Oh, and your choice of learning german, allthough you didn't take it as serious was still much better then mine learning latin :hehe:
    If you got troubles with the german sites, gimme a call as I'm aswell one of those native speakers like lenne ;)
  12. GuilleAcoustic
    26 Nov 2010
    Thanks a lot. I'm really considering working my german.
    Well, back to business ... here is a "raw" design ... lot's of work remaining (I'm not too much happy with it)
    Maybe the blades should be longer and reach the back of the case, giving a feeling of levitation.
    EDIT : I think it looks better with this color scheme
    Dark~3nergy likes this.
  13. jrs77
    jrs77 Modder
    17 Feb 2006
    I'd say it's a perfect and futuristic workstation-design :thumb:
    Look at the plain Z600 or 800 HP-workstations in that regard to know what I mean. ;)
  14. GuilleAcoustic
    26 Nov 2010
    Nice workstations, I like this massive use of blades. I'll redesign the front feets and try to make the top part lighter "visually speaking"
    Just a question .... should I have the I/O port pointing upward or downward ?
  15. jrs77
    jrs77 Modder
    17 Feb 2006
    If you're watercooling everything and not rely on airflow (especially of the GPU) then I'd opt for the I/O to face downwards, as it allows tidier cablemanagement.
  16. Dark~3nergy
    14 Jan 2007
    awesome design :eeek: +rep for that
    If you build it using that board, will you make custom waterblocks for the motherboard ?
  17. GuilleAcoustic
    26 Nov 2010
    for the mobo I do not know ... but I'd like to have a single block cooling the 2 CPU in parallel, nickel platted bended copper pipes to connect everything ... hope I'm not too much of a dreamer :wallbash:
  18. Dark~3nergy
    14 Jan 2007
    i'd say it's possible, although might be complex to make ^^
  19. GuilleAcoustic
    26 Nov 2010
    do not say IT please. IT is hurting me and IT sounds hard to my ears. IT is doable, IT will be done.
    Tell me if IT is enough :D :hehe:
    * ok, I'm taking ITs coat *
    (j/k) ... well, more seriously some Mayhem's pastel cooling fuild would looks awesome I think
    Edit : for those who didn't understand (shame on you ... j/k of course :D) ... take a look at Monty Python and the Holy Grail :thumb:
  20. Dark~3nergy
    14 Jan 2007
    silly french dude, stop mocking the great knight of the sacred words NI ! :hehe:
    back on topic, Vray has been running for 2h30 and there's still about one hour left. i will post the results here ;)
