SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    Love the design of the building. The overall feel of the final render is nice, drawing attention to what's important. I'm not keen on the weird bubbling effect, it takes away from the final result. Can I ask your reasoning for applying this technique?
    It might also be worth looking at the edges of the building again, because there's still evidence of the building being cut and pasted onto the background, with a slight white glow around the upper half (especially against the sky, and far tree), and the edge is too sharp at ground level. An easy way of blending the cut image into the background is to slightly blur the edges.
    The lighting looks nice overall, and really helps give a taste of what the building would actually feel like.
  2. dylan woodhouse
    dylan woodhouse What's a Dremel?
    5 Mar 2012
    hi guys, newbie here,
    i just have one question, why do you do this, other than enjoyment
  3. dylan woodhouse
    5 Mar 2012
    can you download and use these?
  4. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    Having fun trying new tricks can also lead to more work and more money. Getting opinion from others who have experience here is also another mutual bonus...
    Sums up mostly my intention, though im sure others have more practical reason...
  5. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Cheers The "bubbling" effect is meant to simulate water on a camera lenses and I was in two minds about using it but in the end I think it fit the rest of my presentation well. The building design was formulated around wind hence I wanted a stormy scene so the inside looks like a safe haven. Agreed I need to blur the edges it doesn't show up when printed hence I didn't really bother.
    thanks for the comment :thumb:
    I do this for work and for my degree.
  6. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    growing some digital grass for a project:
  7. microsoftPerson
    27 Dec 2010
    I don't think the collisions were working with the first video I made. I came up with a new technique which is working better, it seems you can actually see the ball making its way through the grass now:
  8. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice simulation, although the materials could use some tweaking
  9. microsoftPerson
    27 Dec 2010
    Thanks. Yeah they can use some tweaking for sure. I need a new heatsink, renders are causing my machine to run far too hot right now.
    Not that I don't have any ideas of my own or think it's perfect - would you elaborate on what you think I should do to the materials? The ball is just for play but any input you have on the grass would be greatly appreciated.
  10. Tangster
    23 May 2009
    Here's the setup I normally use for a quick grass material.
  11. microsoftPerson
    27 Dec 2010
    Thanks Tangster, and in C4D format nonetheless! Our materials look pretty similar. I wonder how you're handling the length channel for the hair as mine seems to be really uniform in length even after upping the variation to 100%. Other than the color they are quite similar in their setup actually. I used some clump in mine though.
    Can I ask, if you don't mind. What do the different layers in the color channel do exactly? I figure they just mix with each other like photoshop but it doesn't hurt to ask as some things in C4D are a bit more complicated than they seem. Similarly, should I disregard the inactive layers or do they still have some effect on the material?
    Also, I like that you have some green grass and some brown grass. That looks more realistic to me than the grass that people make with brown mixed in with every blade of green grass as a part of the gradient. But what do you do with that? Can you apply both materials to the hair and get some sort of random mix of the two?
    *edit* I'm also interested in how you set up your thickness channel? Did you make your own curve for the thickness?
  12. Tangster
    23 May 2009
    The different colour channel allow me to quickly change the look of the grass, either by changing which layers are active or changing the blending mode of the extra channel, which could look pretty cool when animated. Other than that they don't affect the grass that much.
    The length is unchanged in mine, they're actually all uniform length. I have a custom curve for frizz that gives the impression of nonuniformity and at the same time a little variation, with 50% frizz and 16% variation. The thickness channel has a 0.2cm variation and just goes from 0.3cm to 0.
    I don't think you can affect the colour of the grass without setting up UV maps, I have two textures just so I can pick and choose which grass I want to use in a particular scene.
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Just playing about with some settings and a few new materials
  14. cronicash
    25 Aug 2009
    Was in a bit of a rush to get the basic shape right. WIP.
    [​IMG][​IMG]
    Yet to add dirt, few more tidy ups and appropriate scene...
  15. cronicash
    25 Aug 2009
    Quick update...
  16. microsoftPerson
    27 Dec 2010
    car looks great to me, did you do the model from scratch? thanks for sharing.
  17. cronicash
    25 Aug 2009
    yeah, all modelled myself...
  18. microsoftPerson
    27 Dec 2010
    Awesome. It looks like a really nice model. (I didn't realize I could open the wireframe image before, looks even cooler now)
  19. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Love your designs man. I've always wanted to peak inside your brain :dremel:
  20. Tangster
    23 May 2009
    Some very impressive stuff Editor and Cronic.
    @Editor, very clean design, looks surprisingly small for a quad rad system.
    @Cronic, that's some great modelling on the car. I never could model cars very accurately.
    The texture looks a little odd, some dirt/damage might help give it a sense of scale. As is it looks a bit like a RC model.
