SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    Like i did on the post below the pic you speak of?
  2. DesignBlueprinter
    DesignBlueprinter What's a Dremel?
    9 Mar 2011
    When you say "creating" do you mean the general look or actually covering everything down to the electronics to where an actual working product can be manufactured?
    You are going to get two totally different lists of recommended software depending on your answer...
  3. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
  4. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    Been insanely busy with my a levels recently and haven't had time to produce any renders! Fortunately I found some time in my easter holidays to blow the dust off of 3ds and indigo and cracked on with some work which has been floating around my mind for a while :geek:
    I've noticed with HDR environments that they produce very even lighting from all directions but there are pretty much no shadows, so I have been editing my HDR maps and increasing the contrast between the exposure from the sun and the sky to give an even more realistic light setup :D Still not quite done yet but getting the hang of it, the shadows are quite a funny colour and this is the only decent result I have but expect more in the next few weeks :rock:
    Anddddd, here is a render i forgot to post back from january,
    lastly, the obligatory greeble render :lol:
    peace out! :rock:
  5. Tangster
    23 May 2009
    Messing around with Cinema 4D and Live movie maker. ME1 style vibe.
  6. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Love it!! Could improve possibly by have the gun spin before the annotation appears then spin once again at the end?
  7. Tangster
    23 May 2009
    I thought about doing that when you suggested it, but couldn't bring myself to done any more frame by frame animation in WLMM, I did edit it a little though, with an added load screen.
  8. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Was bored yesterday. Info in YouTube desciption.
  9. LithiumDesign
    23 Jul 2009
    Stone, no bump maps, 3mil polys!
  10. LithiumDesign
    23 Jul 2009
  11. stonedsurd
    11 Mar 2009
    The stone blew my mind. :jawdrop:
  12. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    that wouldnt happen to be a heat exchanger for a PC cooling loop now would it?
  13. LithiumDesign
    23 Jul 2009
    Nope, it's an old adjustable capacitor, something I found in my dads shack so decided to model it, here is the finished render!
  14. microsoftPerson
    27 Dec 2010
  15. LithiumDesign
    23 Jul 2009
    how on earth did you do that?! :jawdrop:
  16. microsoftPerson
    27 Dec 2010
    I'd feel silly giving you the whole explanation as you seem to have a good understanding of the 3d environment, probably way better than me. It's made in C4D though, which part were you referring to? I used cloners, sound effectors, plain effectors, step effectors, linear fallofs, and C4D's sound effector to sync movement to the music.
    I'm working on V2 and V3 but I'm also working to complete the After Effects compositing and give it a more polished look.
    Did you like it? Thanks for the response.
  17. microsoftPerson
    27 Dec 2010
    v2.0 is coming out so cool.
  18. microsoftPerson
    27 Dec 2010
    Very interested in feedback. They might not be live right away but they will be by the morning.
    They go up to 720P HD by the way. watch em that way, took extra to render ;P
  19. Tangster
    23 May 2009
    I like the first, but the 2nd doesn't quite seem to fit properly with the music like the previous ones did(although it does, since there's no way mograph would screw up). Maybe the effect isn't as pronounced.
    I'd make both a bit brighter as well.
    Good work overall.:thumb:
  20. microsoftPerson
    27 Dec 2010
    Thanks for the reply tangster. I have also noticed that the second one is not as pronounced to the actions of the music as the other. They're actually the same render, just different compositing.. I guess I couldn't resist the geometric fading in of the first one.
