Distributed Bit-Tech Folding@Home Team (CLOSED: now superseded by joint CPC/bit-tech team)
Discussion in 'Software' started by Byron C, 2 Aug 2003.
Thread Status:
Not open for further replies.
  1. identikit
    identikit Minimodder
    5 Jun 2004
    On the SMP client? I know there is a longer pause between WUs to finalise and prepare the unit to be sent.
  2. E-Jungle
    E-Jungle What's a Dremel?
    23 Jan 2007
    Just joined
    I decided to join team Bit-Tech aswell, here's what i'm running atm:
    Laptop: cellyM 1,5Ghz running windows client
    Server: celly 2,8Ghz running linux client
    Workstation: C2D 6600 running windows client
    My destop will start when i get home from work tonight, so there should be some WU's starting to show up today :clap:
  3. identikit
    5 Jun 2004
    Welcome to the team!
    Are you running the SMP client on the C2D?
    I've been having overclock stability issues with FAH. Everything runs solid at 2.7GHz but even at 2.4GHz FAH just runs into errors and dumps WUs :sigh:
  4. E-Jungle
    23 Jan 2007
    I'll try running it again, i've had it running on my C2D before when it was OC'ed to 3,2 GHZ some months ago and it was performing quite stable. But i suppose it was a different version so i'll have to try to find out.
    As I will only be able to start that system working on F@H tonight you'll have to wait a bit, but i'll post my findings here.
    update: seems to be stable.
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Welcme home.
  6. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Just added my PS3 to the Bit-Tech team! :)
    Also using my PC. (2.2GHz)
    -CollinstheClown
  7. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Decided to start Folding years too late, but better late than never.
    Contributing:
    3 x 2Ghz Centrino Duo's
    2 x 3.4 Ghz Pentium 4 HT
    2 x 6300 Core 2 Duo
    24/7
    1 x E6600 @ 3.25Ghz (about 3 hours per day)
    1 x 2Ghz Centrino Duo (about 4 hours per day)
  8. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Joined.
    2x 2GHz C2DM - Class/School
    2x 1.83GHz C2DM - 24/7
    4x 3.2GHz C2Q - When it's on.
    under Many_Miners_With_One_Goal_[EVE-Online]
  9. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    joined....2x 2.54Ghz for 9 hours wheh i'm at work and when i'm sleeping...its pretty awesome the amount of processing power given to the project, good to see people being so selfless, but that might just be a geek thing :p
  10. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Just joined the bit-tech folding team \o/
    Running software on pc in sig :thumb:
    So after running this for a short while, I notice it uses 25% of my cpu (or 1 core at 100%) how can i get this to max out another core or two, do I run multiple instances with same username or a different username, or is there a way to get it to use more cores as I have 4, would be nice to max the box out when im not at home =] and then reduce to 1 or 2 cores once im home and gaming?
    EDIT: got smp, set affinity, better =]
    This is such a great idea, I wish I had discovered and joined earlyer!
  11. zabe
    zabe Perfect in my imperfection
    2 Jul 2007
    hi everyone, just installed f@h in my new intel core 2 duo laptop, let's see if the processing performance is better than in my old amd 3000+!!!
  12. Tsen
    Tsen Steeped In Romance
    29 Apr 2006
    Joined, just one compy. Core 2 Quad @ 3.0 ghz. SMP client, but it only seems to be using the first core...I'll work on that and see if I can get it running properly.
    Anyway, I might add an old single-core 3.0 Ghz later, but I'm currently cannibalizing it for parts, so there might not be enough left to run.
    EDIT: Got the SMP client running a bit better. Set the affinity so it won't run on my first core. Balances my overall usage a bit better that way.
  13. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    got my Athlon X2 6000 running this.
    and i joined the team.
  14. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Bah, hackaday team Cheesecake
  15. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Ahh better late then never; just added my OCed q6600 rig to the team.
  16. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Aw, I joined but it's slow as a very slow thing, not even 1/2000 yet. First WU estimated to take 41 days :jawdrop:
    I'm upgrading this little turd to a C2D soon tho, then I'll actually get somewhere. If I can get my old lappy online I'll get that on the task too.
  17. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    When I get home I am going to add my q6600 to this, but from reading the forums, will it run on all 4 cores? or just one?
  18. Hiren
    Hiren mind control Moderator
    15 May 2002
    Hopefully I can break the top 100 on the bit-tech team before the end of the year.
  19. identikit
    5 Jun 2004
    The SMP client will utilise all 4 cores.
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The BBC are reporting that Folding@Home has broken the petaflop barrier, thanks to the client now also running on 670,000 PS3's.
    Story here.
Thread Status:
