SketchUp Bit-Tech.net Case design contest discussion thread
Discussion in 'Modding' started by Dark~3nergy, 28 Mar 2010.
what theme should be used ?
  1. micro-atx case
    16 vote(s)
    57.1%
  2. mini-itx case
    5 vote(s)
    17.9%
  3. pico-itx case
    3 vote(s)
    10.7%
  4. bit-tech case
    3 vote(s)
    10.7%
  5. other
    1 vote(s)
    3.6%
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    sooooo here it goes.
    i will open the contest the 31.03.2010 at 12h00 but before i want to make sure that i pick a theme that everyone likes.
    the contest will have the same rules as last time, except that it will be 1 month long and 1 month for voting. prices will be announced later.
    so here are the themes i thought would be intressting:
    -micro-atx gaming pc, as small and as powerful as possible
    -mini-itx gaming pc, as small and as powerful as possible
    -pico-itx case, a media centre pc or what ever you'd want it to be used for.
    - a bit-tech themed computer. if the bit-tech staff are fine with that
    or if you have any other ideas, feel free to tell me :)
  2. stonedsurd
    11 Mar 2009
    mITX should be fun :)
  3. Cheapskate
    13 May 2007
    :rock:PICO!:rock:
    -And if I could make the text flash, I would.
  4. confusis
    confusis Kiwi-modder
    5 Jan 2006
    We need to have a fixed motherboard we should use from the SCC collection - maybe my ECS board for m-ATX? (I might end up building one of the designs (for myself))
    Although with m-atx i may have an advantage as all my designs (outside of the contests) have been m-atx for a year or so.
  5. Dark~3nergy
    14 Jan 2007
    i'm working on an high def asus gene II, incase anyone would want that.
  6. Trance
    Trance Two steps forward, one step back
    6 May 2009
    M-ATX!
    I love m-atx! :)
  7. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    +1, I have a Pico ITX board.
  8. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    darky give it to us :D
    hmm but i gotta finish my cnc first.....
    otherwise, bit tech theme ( all for fp, fp for all :D )
  9. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    M-atx sounds great :) would be cool if everyone had to use the same mobo model as standard and the rest is free form .
  10. confusis
    5 Jan 2006
    maybe same mobo, gpu (cooling system excluded), psu and HDD, and the rest is free choice?
  11. motas
    motas What's a Dremel?
    7 Dec 2009
    I thunk either a standard set of components in it (excluding cooling) or design it for someone so it's actually got a use theme rather than I mobo size theme (could design one for me). For the first one having the componnts somewhere would make it better.
  12. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I say mITX :)
  13. lenne0815
    4 Jul 2009
    that would be great ! in the end its the case that shoud matter, not other "borrowed" components !
  14. motas
    7 Dec 2009
    Yer do what confusis said I think that's the best idea
  15. Dark~3nergy
    14 Jan 2007
    having a standard set of component is a really good idea, therefor i started to work on this:
    i will make a water cooled version and air cooled version.
  16. Dark~3nergy
    14 Jan 2007
    also i think that it would be better if it was only the "main" hardware; motherboard, gpu, ram.
    and not psu and hard drives
  17. Bufo802
    Bufo802 Minimodder
    28 Jul 2008
    Would definitely be interested in competing this time, though will have to see how long it takes to competently use autodesk inventor.
  18. Editor22
    3 Jan 2009
    Looks cool dark, I agree with the main components idea but maybe Just leave the GFX and CPU cooling up to contestants, think there is a lot out there that like making custom heat-sinks/water blocks :)
  19. Dark~3nergy
    14 Jan 2007
    how about haveing a fixed gpu, with no cooler, and you can add the one you like ?
  20. lenne0815
    4 Jul 2009
    i really like the idea of having a full set of components, but pls no backplate for me :D
