Blogs Bit-tech on the BBC
Discussion in 'Article Discussion' started by Cutter McJ1b, 11 Dec 2009.
  1. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
  2. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    will definately be giving this a listen, you fellows seem to be getting a few calls from the beeb recently?
  3. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Did you ask why they're called Netbooks, even though most Atom powered ones don't have the power to view the web (ie Flash) properly?
  4. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Really? Guess the netbooks I've owned must have been special as they had no problems with flash.
  5. Psytek
    Psytek What's a Dremel?
    23 Dec 2008
    Why would he ask that... dell don't make the atom... Intel does.
  6. David
    7 Apr 2009
    Took me a while to find it...
    http://www.bbc.co.uk/iplayer/episode/b00pbmmq/Up_All_Night_13_12_2009/
    Near the end, around 3hrs 35mins
    Bit of a shame that the interview with the guy from Dell took up so much of the segment, without actually saying anything.
    It was nice to hear Clive giving Dell a bit of a slap for the muddy marketing of their product range.
    I know that configuring your own machine on Dell's website isn't really of interest to CPC and Bit-tech readers, but I know someone who tried to do just that, got fed up, and eventually went into Curry's and bought a laptop of the shelf.
  7. Xir
    Xir Modder
    26 Apr 2006
    Because Dell chose this processor to power their "Netbooks"
  8. hardflipman
    hardflipman What's a Dremel?
    27 Jul 2004
    The Atom processor copes fine with pain old youtube stuff but fails miserably with anything higher definition like vimeo or other stuff. It's a constant source of frustration for me!
  9. kenco_uk
    28 Nov 2003
    Turbo mode on either the U100 or NC10 seems to do the job with flash-heavy sites. If the GMA950 could 'do' gpu accelerated flash, problem solved, but it relies on the Atom atm, which is lacking unless it's run above spec.
  10. PegasusM
    PegasusM Stand back, I'm doing science
    18 Oct 2009
    Nice job Clive!
  11. Claave
    Claave You Rebel scum
    29 Nov 2008
    Thanks for the link and the time index Spreadie!
  12. David
    7 Apr 2009
    NP.
    It was good to listen to, although you've some way to go before you can be a BBC whore of Alex's magnitude. :naughty: :D
    *runs away, wondering if Alex will delete his account
  13. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    I would do, but I've got to go on the BBC this evening....
    (I'm not even joking.......!)
  14. David
    7 Apr 2009
    :hehe:
    Gonna tell us why?
    Gizza link.
Tags: Add Tags
