Other BitFenix Cables - Opinions?
Discussion in 'Hardware' started by pete*, 25 Oct 2011.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    Does anyone have any hands on experience with the BitFenix set of cables?
    I plan to do a new build in the new year sometime (probably IB, price dependant) and
    I love the look of the BitFenix cables - available in black, white, red, blue etc - Dependant
    on the things I buy for the build (MB colours etc) i'll get matching cables.
    Just wondered if they're any good? Cheaply made, or anything else not up to scratch about
    them? - Apart from being a little more money than basic ones you might buy.
    I've only found them (LOTS of them) on Specialtech so far, Scan has a couple of black ones.
    Linky here.
    Cheers :)
  2. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    I know a lot of people that use them and they are extremely happy with them. From what I've seen they look to be of a very good quality.
  3. TheKrumpet
    TheKrumpet Once more, into the breach!
    18 Oct 2011
    Oooh, I LIKE those! I may have to make some Adaptors for my PSU, otherwise there'll be cables everywhere... certainly going to be getting a few though.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    If you look at my log I use lots of them in my rebuild. I live them, they use a fabric braid which is nicer than MDPC braid. easily worth the money...
  5. KidMod-Southpaw
    28 Sep 2010
    Used plenty of them.
    They're of fantastic quality and look great.
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Used a couple of them in my current machine, wonderful cables, more than enough flex to get to where you need them to go, and come with enough length for even the most ridiculously proportioned of cases.
  7. pete*
    29 Apr 2009
    Cool, cheers guys :)
    I prefer what they look like too, much more. Mainly that they're smaller than your usual cables
    especially PSU ATX cables, less space needed behind mobo tray I guess. :)
    I assume they clip in fine directly into most normal PSUs? Mines Antec Quattro 850 - Which I
    hope is going to be fine for the new build.
