Case Mod - In Progress Bitfenix Prodigy Custom 1 COMPLETED
Discussion in 'Project Logs' started by Bygone, 15 Apr 2015.
  1. Bygone
    Bygone Minimodder
    15 Apr 2015
    ***FINAL PHOTOS ON P4***
    I am pretty sure you are all familiar with Bitfenix Prodigy, but in case someone missed it here it is
    My plans for the prodigy was to make this my first ever Water cooled pc. The plan was to check out the scene find a project that gave me the right gut feeling then adjust that design to whatever would fit my build. I found some inspiration on various Projects, so please bear with me if some parts of this has been seen before somewhere else. The modding i have performed myself.
    First off let me list the intended Hardware:
    Intel I5 - 4690K Devils Canyon
    Asus ROG Maximus VII Impact
    Corsair Vengeance Pro (RED) DDR3-2400 2x8gb
    Asus Geforce GTX 970 Strix 4gb
    Silverstone SST-ST65F-G 650W fully modular psu
    Samsung SSD 850 Pro 256gb x2
    Bitspower VG-NGTX970ADIIS Acrylic Top With Stainless Panel (Black)
    Bitspower AIZ97M7IITX Nickel Plated (Black)
    Bitspower Carbon Black fittings
    EK-DDC X-RES 140 CSQ reservoir
    EK-DDC Heatsink Housing - Black
    EK-DDC 3.2 PWM (12V PWM pump)
    2x 240mm Alphacool NexXxoS ST30 radiator
    2x UN mounts for the reservoir to be mounted on backside of one of the radiators.
    Modding plans:
    - I will be cutting up both side panels, making way to side custom side Windows.
    - I will be cutting and removing both front panel and top panel on the Prodigy to make room for 2 radiators inside this small chassis.
    - I will be mounting a vandal power switch on the backside of be Prodigy, as i will be removing the default power button on the side panel.
    - I plan to learn how to make custom cables as the last part of the project.
    Ok first thing first, i stripped the Prodigy and went mad with my saw :), here was the first result of that.
    i googled for software that i could use to Draw and design my new front panel and top panel.
    here is what i came up with:
    Inkscape Frontpanel Vektordrawing:
    Inkscape Toppanel v1 Vectordrawing:
    I have been moving on this project for some time now and will be posting my Progress within the NeXT few days, far from done yet, but also far from just started :)
    After having checked the content of the drawings and the Measurement i sent them to get laser cut, the front panel was to be a 8mm thick smoked black acrylic and the top panel a 3mm matt black acrylic plate.
    here is what i got back:
    the frontpanel:
    the toppanel:
    Please keep in mind there is still protection film on the sheets here, so they look awful :)
  2. Bygone
    Bygone Minimodder
    15 Apr 2015
    Back to the the drawing board to get the Measurements for the sidepanels, they came out like this:
    the blue area is the cutout area on the Prodigy side panel, yellow is the 3 mm clear acrylic sheet needed for the window.
  3. Bygone
    Bygone Minimodder
    15 Apr 2015
    As this is the first time im joining forces with a dremel :), then im not as Sharp as other handymen out there, but i kinda liked the result of the side panels.
    what do you Guys think...?
  4. Bygone
    Bygone Minimodder
    15 Apr 2015
    and some of the goodies from the build:
    reservoir+pump heatsink+radiators:
    Asus goodies:
    Box of goodies from Bitspower:
    Silverstone PSU arrived:
  5. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Nice work, I like the window design :clap:
  6. Bygone
    Bygone Minimodder
    15 Apr 2015
    Thx :)
  7. Bygone
    Bygone Minimodder
    15 Apr 2015
    Since my update from yesterday apparantly got thrown somewhere into hyperspace, ill try creating it Again :) this post will be some hardware porn, boxes arriving and looking at components
    First off we have the reservoir, the pump heatsink, the un brackets almost not visible at top, and the 2 radiators:
    Then we have some Asus goodies, mobo + gfx:
    and a box of goodies from Bitspower, the gfx and mobo block + carbon Black fitting:
    and here a Little more spread out :)
    I really love the way the carbon Black fittings look :) and cant wait to start creating the Water loop.
    Memory and CPU has also arrived:
  8. Bygone
    Bygone Minimodder
    15 Apr 2015
    And some testfitting of the hardware to see if it all fits in :)...
    I still have fitted the Water Blocks to gpu and mobo, but will do that in one of the NeXT updates.
  9. GregEl
    GregEl What's a Dremel?
    24 Jan 2015
    Why do you use 2 different fans? Great choices for the water cooling though! Keep it up!
  10. Bygone
    Bygone Minimodder
    15 Apr 2015
    I fell instant in love with the White Noiseblocker E-loops i have in the front and had planned to use them on top as well, but they are useless in pull configuration. The red ones are sofar the best alternative i have found but i agree im still not super happy about them.
    Suggestions for any like the eloops that i might have missed or others would be appreciated.
    /Steen (aka Bygone)
  11. GregEl
    24 Jan 2015
    Noctua fans are amazing, but very expensive.
    Corsair SP fans are ok.
    Gentle Typhoons are the good old proven and tested radiator fans, you can't go wrong with them I think.
    Snef uses some nice looking bitfenix fans in his builds.
    Having said that, the fans I would like to try for my next build are Cooler Master Silencio 120 fans.
    They are really nice looking, optimized for radiators (originally sold with CM AIO coolers) and at a very good price I think.
  12. Bygone
    Bygone Minimodder
    15 Apr 2015
    One of the reasons i choose the 2 red ones are due to the color scheme of the build, noctua fans are amongst the best but they would look crap here in this build, id have to find one that besides being a superb fan also fits the builds look.
  13. Bygone
    Bygone Minimodder
    15 Apr 2015
    Time to Mount the Water block on gpu
    enjoy this beauty of a block
    and also the very slick backplate
    One thing to notice here is the height of that GPU, im unsure whether this is normal for gtx 970 Cards or if this is the Asus Strix design, but this will prove to be a problem in one of the updates coming tomorrow from me.
  14. Bygone
    Bygone Minimodder
    15 Apr 2015
    Waterblock mounted on motherboard
    and also time to get a new power on/off switch mounted
  15. GregEl
    24 Jan 2015
    Silencio fans will fit the build nicely I think.
    Good black like the beautiful waterblocks. (I became a big Bitspower fan lately...)
    And the Bitfenix (same brand with your case) come in many color configurations
    The red ones you have are fine though. Keep up the good work!
    Oh the Strix design pcb is taller at the sli bridge, the one thing I don't like about them. Other gtx 970 are different.
  16. Bygone
    Bygone Minimodder
    15 Apr 2015
    Now Pictures from the first test mounting of the mods to Prodigy (what i hoped would be my final mods :))
    Front:
    Top:
    Side 1:
    Side 2:
    all look nice and clean :) until i test fit the Asus GTX 970 Strix and see that it fits but there isnt room for fittings...sigh
    But i must say even though its pcb is higher than normal 970s i love the look of the Asus 970 strix, i also have been annoyed with the current acrylic top that was 3mm acrylic, wanted to change that to 1mm aluminium instead. So this was the higher gods talking to me that my top panel needed changing anyway as i now need to move the radiator/fan Mount a bit away from GPU unit, more on this later.
  17. Bygone
    Bygone Minimodder
    15 Apr 2015
    Here is a Picture of my problem with toppanel v1, can you spot the error? the cue is gpu and radiator are at same height...what wont fit then? :)
  18. Bygone
    Bygone Minimodder
    15 Apr 2015
    So after that small step back it was back to the drawing board.
    this became my toppanel v2 moved the fan/radiator Mount 3 cm from center away from GPU, and to create somekind of gimmick i will create a window above GPU. The orange Square is 3 mm clear acrylic which will be the window.
  19. GregEl
    24 Jan 2015
    Should be better. Will the fittings on the block fit there? Think of the tubing run also near the radiator and the GPU! Are you using 90 degree fittings for the GPU?
  20. Bygone
    Bygone Minimodder
    15 Apr 2015
    Fittings will fit fine even with air around them the Window wont be exactly above gpu, so there is clearance...as you will see below
    first some Pictures from yesterday afternoon...
    I still need to sand it on the edges but did a testfit this morning and it looks great.
