Peripherals BitFenix recon
Discussion in 'Hardware' started by Margo Baggins, 10 Mar 2014.
  1. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Does anyone have one of these?
    I can't seem to make mine do anything - it has a mind of it's own! whatever I set the fans to, they just climb up to max, I can't seem to save profiles as whatever I load isn't the profile I have saved.
    I am either missing something, or these controllers are pants haha.
    I have never owned a controller before, I thought I would jump on something that would be more snazzy than just dials on the front of my pc - starting to regret that decision!
  2. stulid
    stulid What's a Dremel?
    30 Jun 2011
    Hi.
    Sorry to hear about your troubles.
    I personally have not used or indeed seen one of these, I shall ask for you if this behaviour is normal or if there is a setting or something being overlooked.
  3. Shirty
    18 Apr 1982
    Matt, have you got it set to manual or auto? Mine is very well behaved if I make it do what I tell it to :) Never bothered with auto/remote stuff, I'm sat next to the rig when it's on and I speed the fans up when I'm gaming. I switch off the intake and roll the exhuast/rad fan down to 900rpm when not gaming.
    Just set it to manual, select the channel you want, press the fan icon, use the plus/minus buttons to change speed and then press the fan icon again. Rinse & repeat on each connected channel.
    If it's still buggering about on manual then it sounds like yours is misbehaving and needs a good spanking.
  4. Margo Baggins
    28 May 2010
    I removed all the temp probes if that makes any difference? I didn't want them all dangling around.
    I have it on manual - I press the fan, and it shows whatever I have set it to, then, if I press the fan again, it just goes up to full?
    Do you have your usb connected? I am thinking I will disconnect that.
    if I use the software - the fan goes to the speed I choose, then, slowly over 30 seconds ramps back up to full speed. the temp readings are all -1 as there are no probes connected.
    I didn't have time to give it any time last night but I will hopefully have a look at it tonight
    Thanks bro :)
  5. Shirty
    18 Apr 1982
    I use the two temp probes on the channels it's controlling, just to show the airflow temps through the fans (intake & exhaust). But on manual that shouldn't make any difference to speeds.
    When I switch a fan on using the controller it spins up to full speed initially, then over around 30 seconds reduces down to the selected rpm. I'm controlling a Corsair AF140 and SP120.
    I think I have the USB plugged in, but I don't use it (the internet based speed control is of no use to me). I've only ever used the hardware interface.
  6. jinq-sea
    15 Oct 2012
    If it is USB connectable, is there a firmware update or some such you could throw at it?
  7. stulid
    30 Jun 2011
    Some fans are incompatible because of the RPM sensor compatibility.
    That is what I have been told.
  8. Margo Baggins
    28 May 2010
    I can't imagine it's that - I am using standard 3 wire fans, I am not even running multiple fans per channel - and the controller does manage to slow them down and report their speeds, it just ramps them back up again of it's own accord.
    I appreciate the response, but it is a bit of a cop out :)
    Maybe I need to factory reset it or something.
  9. stulid
    30 Jun 2011
    Try that and update me:)
  10. Margo Baggins
    28 May 2010
    Thanks - I had a feeling that pulling all the temperature probes off wasn't going to be a good idea :D
    I will test - have no monitor at the moment, it's in pieces on my work desk as it was flickering so i am changing all the capacitors in it - and I ordered the wrong ones so waiting for the right ones to arrive now! But that should be fixed for the weekend so I will test it then. Thanks for your help.
  11. Margo Baggins
    28 May 2010
    Works now :) connected up the temp probes, now it works completely fine! Thanks ;)
