Hardware BitFenix Ronin Review
Discussion in 'Article Discussion' started by Meanmotion, 9 Aug 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I know the idea is to test an out of the box setup, but it would have been nice to see the case tested with a few more fans installed than the pre-installed two, maybe even just an extra intake fan fitted on the front :(
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Comment Edited.
  4. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    Yes I agree. Testing the out of box set up is important, as it gives us an idea of what exactly our money is buying, but when a case holds extra potential (as this one), it would be nice to get an indication of that potential. Adding a few more fans and scoring the temperatures would do that.
  5. djzic
    djzic Bokehlicious!
    8 Nov 2010
    btw it says 'it's' instead of 'its' on the last page :)
  6. ev1lm1nd666
    ev1lm1nd666 What's a Dremel?
    23 Apr 2009
    Even if you guys remove the stock installed fans and use the same fans in all case tests (as well as the basic test with stock fans) the results will corelate with each other as the placement/number of fans will be the deciding factor with the temps...
  7. badgerz
    badgerz What's a Dremel?
    15 Feb 2005
    Prodigy M is out guys. Wakey Wakey, people might actually buy that.
Tags: Add Tags
